Question about Mitsubishi WS-65809 65" Rear Projection Television
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
Like several others about whom I have read, my Mitsubishi 65 inch HDTV has a flashing green light by the power switch but will not turn on. I tried the reboot and reset procedures to no avail.
Can you help please?
Thanks,
Frank in Jacksonville Florida
jso5302@comcast.net
  • 6 more comments
  • pick apple Nov 17, 2008
    mine is a 55 inch blinks but won't turn on unless i unplug it for four days then plug in and hit resit. it only lasts 1 or 2 days
  • enilc Dec 01, 2008
    I have a 2002 ws-65909 and the green light beside the power button that basically says timer comes on when I hit the on off switch but turns off after about 2-3 seconds before the tv comes on, so i never actually receive a picture. I can try this over and over and it does the same thing. Does anyone know what this is that i need to replace, or will it go away after time. My email is Brad.Cline@bmwmc.com if anyone has any suggestions. Thank you.
  • Anonymous Dec 26, 2008
    Green timer light displays (no blinking, just constant) and tv will not stay on long enough to power up. I do not get a "power on" light, but electrical power is definately getting to tv. Consequently, I cannot get a screen to turn off timer.
  • James Stramer Dec 30, 2008
    Hi i have the same problem my green light just flashes and cannot turn on tv can anyone help
  • Anonymous Dec 31, 2008
    My light wont wont stop flashing either, and I can't seem to find a solution.
  • Anonymous Jan 02, 2009
    BLINKING, WILL NOT POWER UP problem, and notify you when a new solution
    is offered.
    Mitsubishi WS-65809
  • katie55 Jan 03, 2009
    Same problem here. With the green timer light and no picture, Whats up??
  • Anonymous Jan 07, 2009
    SAME GREEN LIGHT COME ON & OFF T V NOTHING
    Genius:
  • 1,239 Answers
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Posted on Jan 07, 2009
  • 927 Answers
Good Day;
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd. The 'DM' board is the big silver item on the left hand side of chassis, looking at back side, loosen all cables to slide whole chassis back.
Replce board then shield. Good Luck, big IRISH. c81a2-3/ c81b2-3, biggest black caps on board.
Posted on Nov 03, 2008
  • 67 Answers
I have problem with screen that bold on top and bottom, and sometime it turn blur, but it working fine after a few hours of use, Please let me know, how hard to fix this problem.
Thank you.
    New Friend:
After instaling dlp chip 1910-6143w the power will not come on only the amber lifht is blinking
Posted on Mar 02, 2013
Thank you.
Posted on Nov 08, 2008
SOURCE:
Blinking red light comes on. no pic or audio
Need to know which one of the lights is blinking red? let me know and I wll assist you with whats causing the set not to power up.
Mar 13, 2013 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP problem, and notify you when a new solution is
if dlp, possibly bad power/digital module. If projection tv, possibly bad picture tube leaked oil onto signal board.
Jan 17, 2011 | Mitsubishi Televison & Video
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV
I thpught I sent this to you already?
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
3,116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
