Question about E-Machines eMachines Desktop PC
Emachine T3414 monitor
I have an emachine T3414 and the brain works but the monitor will not turn on
  • 33 Answers
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Posted on Nov 01, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I cannot find vga, audio, & modem drivers for T3414. Where can I get them from
Access the manufacturer's web-site: http://www.eMachines.com
and click "support" and "download" for your specific model (T3414).
Oct 04, 2010 | E-Machines eMachines Desktop PC
The beeping sound of the emachine desktop T3414 makes a long beeping sound for 4 seconds flat and pauses for 2 seconds and repeats the process. Hope this is a broader explanation of the problem. Thanks.
Open cpu cabinet.
Then refix RAM memory.
Pull processor fan and then processor remove dust from all parts and circuit.
Reattach both processor and its fan.
then check if still face same issue.
Then pull cmos cell from motherbord.
Change RAM memory slot module .
Remove pic cards from PCI slot.
Reattch ATX power connector from smps to motherbord.
Then check.
If still face same problem then your RAM has need to be replaced.
Let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | E-Machines eMachines Desktop PC
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Computer shuts off anytime
Your problem description tells me you may have a failing power supply. Or you may have problems on the motherboard in the form of failed capacitors. I would check the capacitors first. Bad capacitors can usually be found by simple visual inspection. A failed capacitor will appear to be swelled on the end as the exposed aluminum can will show a "domed" appearance instead of being flat, sometimes they will actually split. Look at each capacitor, especially in the area close to the processor/heatsink. If capacitors are the problem it won't be just one! they are replaceable by someone with the replacement parts, and sufficient soldering skills and tools. If the caps look good, I would suspect the power supply.
Dec 15, 2008 | E-Machines eMachines Desktop PC
Where to get memory upgrade installed
open the side pannel then you will see the ram installed in slot, just put the ram module into the empty slot and gently push it, the latch in the side of the slot will close with a click sound
May 14, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
177 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
