Question about Lexmark X83 All-In-One InkJet Printer
Printer does not print correctly.
Just recently my printer does not print in the middle of any document I attempt to print. It scans fine but leaves a middle streak of non-print. I have enclosed a Printer test page to show what it is doing. Thank you in advance if it can be fixed. Earl W. King ewking@pobox.com
    Sergeant:
  • 390 Answers
It sounds like you have a clogged printerhead without seeing test page it is always abasic guide. I would thoroughly manually clean all cartridge printheads (whether on the cartridge or the unit) with cotton buds and proper cleaning solution. Try and print once you reset your ink levels. post back if no help.
Posted on Sep 01, 2007
  • Geraldine Watts Feb 11, 2008
    If this did not work, is the printer by itself or attatched to a pc?
I recently moved my computer and printer. I have an older HP K60 all in one printer/scanner/fax. After the move I had to reset all print functions but when I attempt to go to the director on my pc, it...
Hi This link will show you the step by step on how to rectify the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00112149&cc=us&lc=en&dlc=en&product=59273&tmp_track_link=ot_search
Hope this helps
Mar 06, 2011 | HP OfficeJet k60 All-In-One InkJet Printer
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Unable to Scan documents
If the software is installed correctly it should scan from the scanner, otherwise i would suggest using the scan button on the software screen. Make sure all your drivers are up to date!
May 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Scaned documents have many black areas even in the preview mode.
Open up the document feeder and look for dirt on the scanner glass.
Jan 11, 2009 | HP PSC1410 Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Copies Poorly (black)
sounds like a resolution issue in the scanner settings.
http://tinyurl.com/6qcpgy
May 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
