Question about Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 6100/s Front load washer
Door open light flashing when i set the wash to any cycle, it will begin the wash but after a few seconds door open light starts flashing. Unable to do a wash, I have checked the filter and it is clear.
  • Anonymous Mar 23, 2014
    Lock light started flashing during the wash cycle and the wash cycle stopped. Pump is running with no water. Power and start buttons not working. Door won't open.
    Scholar:
  • 62 Answers
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Posted on Nov 01, 2008
  • Chad Houston
    Chad Houston Nov 01, 2008
    Just to clarify, this is the switch that tells the machine that the door is closed. And the actuator will be on the door, and come in contact with the switch when the door is closed. It could be either the switch (inside the front cover) or the actuator (on the door).
  • Whirlpool Master
  • 19,396 Answers
That is either a faulty timer control, or more probably a faulty door latch.
I think you need to replace the door latch.
  • Ginko
    Ginko Nov 01, 2008
    The door latc has a sensor that tells the control board when the door is not closed.
    Most likely the problem is a defective door latch sensor.
    Try using a pen tip to play with the sensor, if that does not work , replace the door latch.
    You can buy replacements here.
    Or here.
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Whirlpool AWM 8143 - Starts a cycle and then starts flashing open door light and won't go further. Door is shut properly. Tried turning it off at the power and back on to no avail.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Jan 18, 2011 | Whirlpool AWM8143 Front Load Washer
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 8103/S Problem
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Oct 07, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
820 people viewed this question
Dan Webster
Dan Webster
Sal De
