Cannot insert new ink cartridges - Office Equipment & Supplies
  • Anonymous Apr 26, 2009
    i have almost the same but my printer is not letting me put the ink in it.
    Master:
    Sergeant:
  • 461 Answers
Not Sure what printer you are using, please provide the model or you may want to check below link which might be helpful to solve your problem..
http://etech.maiila.com
Posted on Nov 01, 2008
    Problem Solver:
  • 15 Answers
Rosie,
The Cartridge you purchased, Is it the same Manufacture as the Printer? If so what type of printer is this and what is the Cartridge #
How do you insert ink cartridge?
hi may.
you have not said on what printer.
but go to this link might help you out.
Remove the old ink cartridge and install the new ink cartridge.
  1. Make sure the printer is turned on. ...
  2. Open the top cover of the printer. ...
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage.
More items...
Replacing Ink Cartridges - HP Support
How do you insert ink cartridge Google Search
Nov 06, 2017 | Office Equipment & Supplies
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
After inserting new cartridges jobs no longer print. If you go into maintenance mode on the printer it scrolls a message "align cartridges" across the display. If you press the Check mark button at that...
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
It is possible to get a Dell Series 9 ink cartridge with a bad sensor. Take it back to the place of purchase for a replacement.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Inserted new cartridges..orange light still on
Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
Jun 17, 2009 | HP DeskJet 880c InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Installing new cartridge
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Mar 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
313 people viewed this question
jasbo
jasbo
