On cannon pixma mp610 printer messge on the printer says inner cover is open.close inner cover and press ok. I did that and pressed reset and still get this message. Cover is closed and I cannot get the printer to print. I did replace black ink tank yesterday and the light that all is well with the ink lamp is lit
    Master:
    Sergeant:
  • 461 Answers
Try to reset the printer, power off, remove the main supply cable, leave it for 1 minute... and restart the printer...below link might be useful for more troubleshooting tips..
http://etech.maiila.com
Posted on Nov 01, 2008
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Problem with my Canon Pixma MP500
Try a hard reset first: Unplug the printer from power source and PC, wait about 5 minutes and replug. Should the issue recur, then the cover sensor is probably faulty. That is the reason you are getting this error repeatedly. The only solution is to send the printer in for servicing and get the sensor repaired/replaced.
In any case, here are the steps to close the inner cover:
1. Press the Open Button (1) to open the Paper Output Tray (2).
2. Raise the Scanning Unit until it stops.
3. Close the Inner Cover
4. Now close the Scanning Unit.
You can also try reinstalling the printer software along with any patches, updates, etc from the Canon website. Make sure you uninstall the existing software first though..
If neither works, then its time to take the printer in for servicing. You could try to contact them by phone first:
  • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
Hope that helps!
Jul 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
The inner cover (flap in front of cartridges) is closed but the following sign keeps reappearing "inner cover is open. Close the inner cover and press ok".
When the message shows means inner cover sensor is faulty so it cannot detect inner cover state correctly. Try to clean the contact sensor with contact cleaner is good idea since it sometimes an oxidation occurs. Many times I success fix the problem like this.
Regards,
PrinterClinic
Jan 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
What does the trouble code on a cannon printer
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Thanks.................
Jul 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
CD printing error 'inner cover is open'
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
I hope it helps!!!
Nov 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
218 people viewed this question
jasbo
jasbo
