Question about Sony KP-51WS500 51" Rear Projection Television
Botched Repair, now what
My Sony KP-51WS500 had convergence ICs go bad. I had it repaired for$528.00 (ouch). When the TV was returned the color alignment was terrible, and there was still a pin cushion effect. They came back to fix it, 2 weeks later, and at 6pm. It is better but not as good as it was. They did a lot of fine 'local' adjustments on the cross hatch pattern. Now there is still a bit of a bow in the picture and things that should be straigt across the screen, have a bit of a wave to them. I still have a Size Limit Error on the Auto Registration function and a Vertical deflection stopped self diagnostic message. I'm quite frustrated with the company I went through. I will be dealing with them. In the meantime, do you have any suggestions? Thanks, Ken
    Sergeant:
  • 337 Answers
I would only suggest to get back to the people who service the set until they get it right.They have to finish what the started.
Posted on Sep 21, 2006
Why is my tv in 3D?
The convergence is regulated by two ICs. When the convergence ICs become faulty you get colors not matching and shapes show kind of colored halos that may resemble a 3d effect.
The problem is fixed replacing the two ICs. The repair requires component testing and precision soldering experience and must be done by a technician.
Jan 10, 2012 | Sony KP-51WS500 51" Rear Projection...
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
The 3 colors are not ligned up and the picture is out of focus. We tried the flash focus and that did not work. we tried the convergence but are unsure on how to use it.
Colors misaligned in rear projection tv due to failure of convergence output ICs and replacement of bad ICs will solve your problem, it needs soldering work in tv circuit board with proper tools, if you are handy with electronics stuff repair ad can replace parts in circuit board then let me know to provide you more info OR contact local tv repair shop to get tv fix.
Thanks.
Oct 31, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a kp-51ws500, that comes on the colors get wierd then it shuts off, any ideas? Lamp?
Not Lamp, it is problem of convergence output ICs failure. KP-51WS500 is rear projection tv that has 3 color tubes to make picture, this tv does not have Lamp as light source in DLP tv.
Replace convergence output ICs to fix the issue. Local tv repair shop will help you if you have no experience in electronics stuff fix.
Thanks.
Jul 27, 2010 | Sony KP-53V75 53" Rear Projection...
There is a convergence problem . color distortion.
Know how to solders?Replaced the 2 convergence ICS,some or all the resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 03, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture bowed and colors don't line up on my Sony KP-51WS500 Sony KP-51WS500 its bowed and words show up different colors like in 3s.
This is a convergence problem that can be as simple as poor solder connections on the convergence ICs or defecive ICs. If you can solder you can repair this yourself, Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
May 13, 2009 | Sony Televison & Video
Sony KP-51WS500 Rear Projection TV colors are distorted.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 05, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
