Question about Sony STR-DB870 Receiver
No audio reciever will not operate and displays protector on the display
  • 4nik8r Nov 04, 2008
    what are the ic's
    Genius:
  • Sony Master
  • 1,550 Answers
Audio amplifiers IC´s damaged you need to change it
Posted on Nov 01, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G Nov 05, 2008
    the Ic´s are the parts who amplified the sound on your device they are put in an aluminum heat sinker
The display shows PROTECTOR and there is no sound
This means that the amp has detected a short, or low impedence and has shut down. check all the speakers for bad connections and shorts.
Apr 18, 2015 | Sony Stereo Reciever Str-d1090
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
I hava an accurain 5048,reciever sound shuts off,protector reads
as you have described the unit is in protect mode. disconnect all cable/wires to this unit. - and try again. if it is still in protect-a definate short within this unit.
Mar 06, 2010 | Audio Players & Recorders
TXSR875 reciever display
Hi and welcome to FixYa,
Two possibilities:
  • the Pure Audio feature has been engaged. This turns off the receiver's front panel display;
  • heat related issue. A common fault that develops is component failure, specifically, R9304, a 10 ohms dropping resistor connected inline with the +44V display supply.
Should you be considering a DIY (do-it-yourself) repair, please postback for procedures. Otherwise you may have to seek the services of an authorized service center (specially if under warranty) or a qualified professional
Hope that this be of initial help/idea. Good luck and thank you for using FixYa.
Mar 31, 2009 | Onkyo TX-SR875 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Sony STR-DB870 Receiver Logo
155 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
