Question about Cell Phones
I have a mki 9200 just new out of box and connected to a vw polo using sot 976 , the wireless remote dosent work and i have tried chaging the battery , also when using phone the mki9200 only works 1 speaker. help , please
U have to hold the green button and play button at the same time and press the red button that should link it up with the unit
Posted on Jan 25, 2009
Mu VW Polo (Mark III) MATCH, which was first registered in Nov 2001. It has 62,850 miles on the clock. I recently developed a problem engaging gears, especially in 4th and 5th, with a grinding noise. The...
Hi Val,first of all the gearboxes for all vw are made in the same factory in germany and if one model of car was giving trouble the whole range would suffer.i.e.SEAT/SKODA/AUDI/VW.I have not heard of any specific cars giving trouble.but to answer your problem,get the linkage checked by a dealer as these tend to wear and a specific tool is required to set them up properly.and while they are under the car get them to change the oil for the gearbox.you do not need to get a NEW gearbox as a reconditioned one is MUCH cheaper.if you want to down that road.(you will still need to get the linkage set up).
hope this sorts it out for you.regards. geoff,England.
Dec 28, 2010 | Volkswagen Polo Cars & Trucks
Vw polo fuse box layout 2004
you might find the fuse diagram on the inside of the fuse box cover under the hood.....hope this helps.....cheers
Jul 26, 2010 | 2004 Volkswagen Golf
VW POLO 1.9CL Diesel 1997 wont start
hi from uk check the main lead from battery+positive to the starters solenoid is secure ? also there is a thin wire that also connects to solenoid on a terminal of its own this is the solenoid energizing wire that works starter when key start position is selected if all above is ok? then use a jump lead and connect one end to battery negative post then the other end of lead to a suitable earth point on engine ? then try starting? if it works/starts ? you have a bad earth connection to engine from battery negative lead check the earth lead connection at point on engine is clean/secure ? it usually is secured by bolt at point where engine and transmission connect ? hope this helps?
Mar 26, 2010 | 2001 Volkswagen Golf
Vw polo 1.4 petrol stater just clicks
your starter relay has probley u/s
Mar 30, 2009 | 1999 Volkswagen Golf
Why is not there a VW Polo 6N listed?
if warning light control not working change the altenator
Feb 21, 2009 | Volkswagen Cabrio Cars & Trucks
VW Polo Immobiliser P Reg
if not the key probably the reciever in the ignition switch for the immobilizer transponder
Jan 09, 2009 | 1997 Volkswagen Golf
1992 VW Polo 1.3L Coupe: warning light mystery
Bought a very reputable diy service manual for the vehicle, and that plus a bit of thought and nous gave me the cure: no intrinsic problem other than loose relay connections. Went round with the wiring diagrams as guide checking all electrical connections in tight and relays fuses etc all good. Switched on and no problem any more.
By the way, vehicle is 1992 VW Polo - not Fox (which in UK is a variant of the Polo)
Sep 06, 2008 | 1992 Volkswagen Fox
Cell Phones Logo
97 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
