Question about Microsoft Windows XP Home Edition
Cannot upload files
Win XP HOME sp2
Cleaned registry, now DSL speed test shows upload speed = 0.
I need the services log on and start up type for uploadmgr.
Tried system restore to previuos known good point-no joy.
Everything else works.
Cleaner removed registry and application entries.
Event manager only shows uploadmgr fails to start as NETWORK SERVICES. If I change it to LOCAL, I can manually start it, but does not solve problem.
File uploading to the internet fails on all browsers.
Not being blocked by firewall.
I hosed something in the registry. Any ideas on what to add back in to fix this?
  • bitwise Nov 02, 2008
    Tried re-registering OLE and Explorer\...
    Did not fix it.
    Why would I do that?
    Please re-read my original post.
    Sergeant:
    Champion:
  • 275 Answers
Try running dial a fix and than try again
you can download this from gur.in from the download section its free
Posted on Nov 01, 2008
  • Ali Khambati
    Ali Khambati Nov 02, 2008
    download malaware bytes , trojan remover and superantispyware from the same www.gur.in and run them in the same sequence
    and than run dial a fix
  • Ali Khambati
    first of all somthing is creating some issues with the services and its either not letting to start at all or blocking the ports ...
    and also the applications i told you wont harm your system in case if it doesnt correct it the dial a fix resets the services priorities
    malware bytes deletes anykind of rockitt services
    superantispyware deletes spywares
Remove write protection
This could be a Windows Registry setting that disables you from writing to your flash drive (or formatting it). If you are running Windows after Win XP SP2, you can change that setting.
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Apr 27, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Sandisk 16gb memory stick is in write protected
    Important Note:
Feb 12, 2014 | SanDisk Electronics - Others
Laxar USB blocked
    Important Note:
Jan 18, 2014 | Electronics - Others
How can I unlock memory card or remoove the write-protection
    Important Note:
Nov 18, 2013 | Electronics - Others
Cannot install fax services in xp. running xp
This might help:
http://support.microsoft.com/kb/306550
Are you using the correct CD to your Windows version?!
Sep 17, 2009 | Microsoft Windows Xp Home Edition Sp2...
How to enable the win keys in windows ?
To enable the windows hot keys win + key... do the following steps
start > run > regedit
naivigate to
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
find a key named NoWinKeys  and set the value to 0.
Value Name:NoWinKeys
Data Type:REG_DWORD (DWORD Value)
Value Data:(0 = disable restriction, 1 = enable restriction
this will turn on the windows hot keys.
Aug 09, 2009 | Microsoft Windows XP Professional SP3 Full...
Win xp log on failed
to avoid this problem you run in safe mode option to your system.to run in safe mode follow the step...
restart the system and then press on start F8 key from keyboard then choose safe mode option...
your windows has corrupted.
so you can also restore the system in previous date.....further detail on live chat
Apr 14, 2009 | Microsoft Windows XP Home Edition
How will i restore deleted userinit file in system32 folder?
Insert the original Windows XP CD (Windows XP with Service Pack 2 is preferred, but not required) and reboot the computer. You may need to configure your computer to boot from the CD-ROM drive.When the Windows XP Setup has started, press "R" to "repair the Windows XP installation using Recovery Console".
Select the Windows installation to repair (generally this is C:\Windows) by typing its number and then pressing ENTER.
Type the Administrator password and press ENTER.
Type the following commands:
D: [ENTER]
CD I386 [ENTER]
EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32 [ENTER]
NOTE: If your CD-ROM drive has a different letter assigned to it, enter "X:" instead, where X is the appropriate drive letter.
After entering "EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32" you should see the text "1 file(s) copied", in which case all went well.
Remove the Windows XP CD, type "EXIT" and press ENTER to restart your computer. You should now be able to log on as normally.
Mar 05, 2009 | Microsoft Windows Vista Home Premium with...
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
Microsoft Windows XP Home Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
