Question about Juki TL-98Q
Needle thread breaks while quilting on machine frame
My Juki TL-98Q has been working just fine, except on my latest machine quilting project. I have the 98Q paired with a SuperQuilter frame and am using the Quilters Cruise Control. I have followed Juki instructions for quilting; i.e., drop feed dogs, set stitch length to "0", green pressure bar set at top. Am using Coats and Clark Star machine quilting thread in the needle and RSC rayon embroidery thread in the bobbin. The stitches are even but after several inches of stitching, the thread breaks. I have changed to needle, which is a Schmetz 130/705 H-Q No. 90 Can't think of anything else to try. Bobbin thread moves easily from bobbin, as does the needle thread.
Any suggestions would be very much appreciated. Ann Lillich, Cimarron CO
  • 4 more comments
  • abbsmcnabbs Nov 11, 2008
    I have the QE with a New Joy frame - the first quilt I had on there worked fine, the second one kept jamming on the bobbin, and now this third one the needle thread is fraying. I have tried adjusting the tension, changed needles, changed thread - all to no avail. My dad says he thinks there's something wrong with the way the fabric pulls through when it's on the frame, but I think it's got to be something else. Next I am going to try Sewer's Aid thread lubricant...
  • judymorrill Nov 22, 2008
    My juke TL98QE worked wonderfully for a while, now the needles keep breaking and my thread breaks all the time. I am now using #30 cotton thread; I tried the #16 needles as the manual said, but it skips and breaks constantly. I put the #14 needle in; it skips hugh stitches, etc. I am beginning to be very disappointed in what I thought was a great machine.
  • RNFrosty Jan 26, 2009
    I have the same problem. I have a Juki TL98QE, and it is driving me CRAZY. I'm using a grace frame and grace sure stitch. The machine sews like a dream when not on the frame and quilting. HELP.
  • trudy151 Apr 16, 2009
    janome 1600P DB sewing machine, I can't keep it threaded while quilting
  • Joyce Jul 20, 2012
    I had same problem on two different machines both on the Inspira frame, did all of what you did. Are you still having problems.
  • Jane Low
    Jane Low Aug 28, 2012
    I had the same problem - changed needle, bobin, thread, oiled machine finally took it to the shop and it was the top tension that I could not get fixed on my own
    New Friend:
I posted question about top thread breaking when quilting (using walking foot). Finally solved my problem, my solution may help others. Decrease the presser foot tension to nearly 0. Had tried different threads, tension settings, needles. Nothing worked until I adjusted the presser foot tension. Quilting went like a dream, even through seams ect, also worked for attaching binding.
Posted on Feb 15, 2013
  • 3 Answers
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Posted on Dec 16, 2008
  • debalbert397 Jul 16, 2011
    Tried everything read entire book followed all directions several times and tried helpful suggestions here. thread still breaks after a few stitches... I want to throw this juki TL-98Q out the window sigh... This is the worst machine I have ever owned... grrrrrrrrrr
    I went through this and gave up on two machines. Did you get it to work?
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
Started machine quilting; first pass went just fine, rolled up quilted portion, then started machine again but the bobbin thread broke and continues to break. Took out bobbin, reset it in case, etc. N
from what you said about the bobbin thread continues to break
check for burrs in the following area--even the smallest burr can cause problems
bobbin case
needle plate
needle could be damaged
or bad thread
Feb 10, 2012 | Juki TL-98Q
I was recently given a TL-98Q Juki. I have it set up on a long arm quilting machine. I have put two sheets with cotton batting between on the machine. Everything is set up. I started the machine and...
Be sure you have installed a brand new needle. If it still does not pick up the bobbin thread, the machine may be out of time.
If the presser foot does not set firmly on the fabric, then that is what you want for free motion quilting. However, if you mean the presser foot is sloppy (wobbly), then the attachment may be loose or the presser foot is worn.
Jun 21, 2017 | Juki TL-98Q
When free motion quilting I get loops on top of the fabric and on the bottom when doing tight curves. I also get thread "puke" - tangles and snarls on the bottom when going through the quilt...
Check the height of the quilt under the machine-adjust the bars until the quilt is just barely over the bed of the machine, and level front to back and side to side. Also, level up the frame, using a long carpenter's level. You'd be surprised how much this can help with all sorts of thread problems.
Feb 23, 2011 | Juki TL-98Q
I have a JUKI TL-98E, purchased used in great condition. Having a problem with the needles breaking, worked fine when I first got it. Rethreaded the machine and put in a new bobbin and the problems...
I had problems as well, especially when trying to outline quilt. I found using a Schmertz Metafill needle, or an embroidery, anything with a larger eye, helped.
Jan 30, 2011 | Juki TL-98Q
Thread breaks when free motion quilting...what tension should I be at?
Firsrt, try going slower, especially on curves. The Juki is so danged fast, it's easy to run faster than the thread can handle. As far as tension, the best approach is to experiment with a scrap quilt "sandwich" until you find the best tension settings. Also, could your problem be with the thread you're using? Different threads call for tension adjustments. Try using a bigger needle-smaller needles can "cut" the thread, as can defective needles, especialy on curves with free motion. Tension issues are, without a doubt, the biggest problem I've had, but patience and experimentation will usually solve whatever is going on.
Jan 16, 2011 | Juki TL-98Q
I am trying to sew a quilt on a Grace frame and the needle keeps breaking. Any ideas would be appreciated
It could be you moving the machine to quickly?
I use size 14 or 16 needle.
May 11, 2010 | Juki TL-98Q
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Several things to try, I have this set up and after six months I'm still trying to get some issues resolved.  First make sure the machine is treaded correctly, the Juki doesn't thread like most machines, make sure you have the bobbin going the correct way.  After the machine then it has to be in the frame which means that the fabric is most likely to tight, this is a common problem, if you are bending the bars then it is too tight.  Also, look at how the quilt is in relationship to the frame, is it level?  As you quilt and roll, you will need to adjust the frame up, the quilted part should not drag on the machine and the to be quilted part should not be below the machine.  It is a critical that the frame and the machine be even with each other, if not the machine will try to pull and won't sew correctly.  Also, another tip, after each quilt change your needle, the reason is that free motion is technically bending the needle.  Hope all this helps.
Sep 09, 2008 | Juki TL-98Q
Juki TL-98Q Logo
1,361 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
