Question about Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
Trying to self clean our Electrolux Icon oven for the first time. Have removed the racks and rack supports. However, when I press "clean" it still displayed "remove racks" and won't start (beeps three times instead). Frustrating!!!
  • 9 more comments
  • jennieyumyum Nov 09, 2008
    I have the same exact problem! I was here searching for an answer and instead found a soulmate! My Icon oven is also new, I have removed the racks (though not the rack supports, as they are structural and shouldn't NEED to be removed for a cleaning cycle) and keep hearing the same three beeps...can anyone help us?
  • Anonymous Nov 25, 2008
    I have the same problem!  Thanksgiving is in 3 days and I want to get this thing clean before!  I've removed the racks and it is still beeping at me to remove the racks for cleaning.  Can't find any help!
  • Mischelle F Nov 29, 2008
    I have the same problem!!!!! Mine is brand new too. I have racks and supports out and light keeps flashing. No beeps even-help...
  • Margarida Dec 07, 2008
    Same problem here - took out racks, self-cleaning won't start - just beeps after I press start and doesn't get going. I'm stumped!!! I might call their service department - the oven is only 6 months old!!
  • dwkelly Dec 11, 2008
    Same problem here. This is my second oven. The first one locked and wouldn't unlock after it preheated and was ready to go. Technician "fixed" problem but ended up creating another one. I was w/o an oven for about 2 weeks. I am hoping to resolve this problem w/o technician coming out again.
  • Anonymous Dec 15, 2008
    I am having the same problem as everyone else is! Can't get my $2,000+ Electrolux oven to self clean! I figured it would be an easy task as this is my first time do this and my old oven was simple to clean. To hear that I would need to call in a technician with a brand new oven is aggravating!
  • asutt Jan 28, 2009
    Same problem. Have run the clean cycle on top oven, but bottom won't start after removing racks & supports.
  • Anonymous Apr 09, 2009
    Have removed racks and supports and still have the same problem. Also "rebooted" the oven by turning power off to the oven (at the circuit breaker) and then back on. Still does not work.
  • Anonymous Mar 13, 2014
    clean oven racks
  • Lisa Moore Nov 04, 2018
    We did all the tips but with no luck until my husband wedged a screw into the sensor switch on the upper left part of the oven in the top bracket. The sensor switch was out but not enough, so wedging a screw into it pushed it all the way out! After 2 years- my self cleaning option finally works!!!
  • Charlotte Crowder
    Charlotte Crowder Mar 31, 2019
    More garbage products I see. So tired of empty promises from manufacturers. It wouldn't be so bad iftheydidnt promise it. My bottom oven will clean but do I dare risk being locked out. Paper towels and oven cleaner for me. Too bad wedding have a government agency that forces these people to have truth in advertising.
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
  • 4 more comments
  • 4camp Oct 24, 2010
    The left rack guide must be removed first. I cannot find it in the directions but the help line provided the tip.
  • bert Oct 16, 2011
    Once you remove the racks, you should be able to clean it. If it still flashes remove racks, open door and look towards the back of oven. There shlud be a metal bar that goes in when you insert the racks and swings out when you remove them. Try pushing the bar on back and forth a few times. That is where the sensor is connected to that tells it the shevlves are removed. It took 30 mnutes to figure out but it worked. If it doesn't then the lonshot is the sensor is broken and you'd have to get it replaced. You only rmeove the racks when you clean it so the sensor may be stuck so by moving or fliping thr bar that should loosen the sensor. Good luck.
  • coltom
    coltom May 02, 2012
    Our oven is a floor standing gas version. We did not have to remove the rack supports on the side of the oven walls. On the upper left hand rack support near the back is where the small metal nipple sits that detects when the racks are in place. There is a small circular piece of metal on the oven wall just below where the nipple sits. The nipple is hard to find because it is in the narrow space between the rack support and the oven wall. Our nipple was stuck in position because some cooking debris was keeping it from moving. We scrubbed it with a small bristle brush and it freed up immediately. As soon as we could feel the nipple moving freely the oven went into cleaning mode without any problem.
  • abby Rapier May 09, 2013
    just figured it out. the side racks on walls of oven, left and right need to be removed too!!
  • Kimberly Portraiture
    Kimberly Portraiture Mar 25, 2017
    All racks are removed and I am still getting the error message.
  • Erin Niksick
    Erin Niksick Mar 03, 2018
    Just figured mine out. Thank you!!
I had the same problem, but it is easily solvable. You have to remove the racks AND the rack supports on the sides. Just gently pull them up and they lift right out. They snap back in the same way.
Posted on Apr 09, 2009
    New Friend:
After removing all racks and rack glides from the side the "racks" light was still blinking and self clean didn't start.
Calling Electrolux it's a wast of time, the most you get is the phone of a local service company.
Found the solution myself, on the top left side, inside the track holding the rack glide, there is a switch. This is how it knows if rack is present. It was stuck, jiggle it a bit and self cleaning works
Posted on Dec 23, 2015
  • 1 more comment
  • Frances Thomas
    Frances Thomas Jan 16, 2018
    Thank you so much!!! That little switch was something that I never would have seen or known about without reading your post. Saved me from having to call the Electrolux phone number. I have double wall ovens & the bottom oven self cleaning worked fine yesterday, but I tried multiple times with the top oven & it wasn't until I used a knife to jiggle that switch several times that it worked. It's now working -- Thank you again sooo much!
  • Gary Gage
    Gary Gage Jun 02, 2018
    Thank you! This was exactly what I was looking for.
  • Tammy Cote
    Tammy Cote Oct 09, 2018
    Any chance you could post a pic of that switch? What I think is the switch, doesn't move, it's like a clasp with 2 arms that holds it in place. pic attached
Best solution by crookedrn was most helpful and solved the problem. I had no idea those side racks would come out -- and, in fact, one of them didn't come out easily. I needed to use a little leverage with screw driver to loosen it enough to lift it out. NOTE TO ELECTROLUX-- we should tell the company that these side racks are greasy and filthy, too -- so design them so we can leave them in and get them clean, too. The fumes from the cleaning cycle have begun as i type this. Thanks crookedrn. All the best, susan
Posted on Apr 10, 2010
  • 1 more comment
  • Terry Knight
    Terry Knight Dec 23, 2013
    I have used the self clean feature many times in the past. I have removed all racks including the side wall racks. I am now getting the "remove racks" flashing, beeping and it won't let me progress with the cleaning.
  • Terry Knight
    I Checked the nipples that are on the side wall and they are free and they are spring loaded and move easily.move easily.
  • Ani Pecoraro
    Ani Pecoraro Dec 23, 2013
    We did everything the clean option won't work
I removed all racks, including side racks, and the it still read "remove racks", since I still had to cook I replaced the racks, called the technician, and removed the racks to clean them. I tried again the clean cycle and it worked. Maybe I originally pulled the racks to quickly. So try to put the racks back and then remove them.
Posted on Jun 17, 2010
I just had the same problem, I didn't realize that one must remove the side racks also. Once you do that, no problem.
Posted on Nov 19, 2010
    New Friend:
I had the same problem, have cleaned before so I knew to remove the racks, I had already giggled the button switch on the wall of the over where the rack sits, but still told me to remove racks. So I i put in the side rack that holds the switch in, turned on the oven, let it heat until about 300, turned it off removed that one side rack, and viola, it works! thanks for the tip.
Posted on Oct 09, 2016
    Problem Solver:
I have used the self clean feature many times in the past. I have removed all racks including the side wall racks. I am now getting the "remove racks" flashing, beeping and it won't let me progress with the cleaning. I've replaced the racks, set it onto bake (thinking I'd reset it's self) - no avail. Now what?
Posted on May 22, 2011
  • RCMax Feb 02, 2013
    I have the same problem. Electrolux paid for the repair while under warranty but it is happening now AFTER warranty. Electrolux has now offered to pay for parts but not labor. But the bill I got was labor only! The culprit is the spring that recognizes if the racks are out. It is faulty. My brother has the same range- had a $350'repair after warranty expired and Electrolux, he tells me, would not help. I would not buy the oven. If I had it to do all over, only because of poor. Customer relations.
    New Friend:
Hey there,
We have had the same problem. Our model is the gas 30" dual fuel range, and the rack sensor on the upper lefthand bracket at the back is a metal prong that springs in and out when the rack is in place. Nothing was working so I tried loosening the screw that holds the pronged sensor in the oven wall (the screw goes through the bracket for the rack, but is a different head style than the type that attaches the bracket to the oven wall). It may have just been luck but this actually worked - it must have shifted the prong just enough to disengage the sensor. The oven is happily chugging away on its self clean cycle. Certainly seems like a design flaw! It may be wise to retighten it after the cycle completes.
Posted on Dec 31, 2016
    New Friend:
We also had the "remove racks" signal continue as we had already removed the racks and supports. We read above about putting the racks in, heating the oven for awhile and then shutting of the oven, I I then removed the racks and supports and pressed "clean"...it worked.
I last summer placed the racks and supports in a huge plastic storage container. I put in the static sheets for the dryer and then stirred. I placed the racks and support in to soak over night. It made cleaning so easy. Just lightly used a cloth to polish it up. I googled this option. Can do in bathtub but didn't want the mess or the chance of scratching the tub.
Posted on Feb 23, 2015
    New Friend:
Had same problem with top oven but successfully cleaned bottom oven with no problem (i.e. it turned on despite the side racks left intact during cleaning!)
***Now my question is: what is the best way to clean the filthy side racks?
Posted on Jan 06, 2013
SOURCE:
Message to remove racks when trying to self clean,yet all racks have already been removed.
This message is a reminder to make sure the rack are removed only. If they are removed then continue with the self clean cycle. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 22, 2016 | Electrolux 30" Built-In Single Electric...
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon range won't self clean - "Remove Racks" displayed
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
We have an Electrolux Icon oven and cannot get the self cleaner to work. We removed all racks (including side racks) turned it to clean and nothing happened. We shut off the power and turned it back...
There is a small white plastic triangular switch that needs to be in the out position for the oven to recognize that the racks have been taken out. Look at the back left side WITHIN the upper rack support channel. (This is not the small U-shaped piece that can be seen slightly lower on the wall oven.) If the switch is still depressed, with power turned off at the breaker, depress the switch using a small screwdriver. It should pop outwards to the proper "racks out" position. When we had this problem and recycled the power, we again got the signal. Husband switched to a nonconductive tool and repeated the depressing/releasing of the switch while the oven was giving the "remove racks" command. It sensed that all was well and now operates properly. If this does not fix the problem, you may have to replace a board $$$.
Aug 01, 2011 | Electrolux ICON Designer E30SO75ESS Oven
How do i turn on the self clean? i punched clean and it told me to take the racks out. i removed the racks, but it keeps telling me to remove them and will not do anything else?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 14, 2010 | Electrolux Ovens
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
17,397 people viewed this question
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
jdthefixer
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
