Question about Panasonic SC-HT740 System
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
When i power on, the tray pops open, the light says Hello->Init->DVD HO1 error, and the lights go off. However, when i press the Open/Close button, the lights come back on and repeat the sequence of messages, the tray closes and pops open, and the lights go off again.
I'd like to use the external port (iPod), even if the DVD player is jammed - Is there a quick way to change the mode to External Port/iPod, without an extensive servicing of the DVD sub-system (which seems to be a mechanical issue)? I'd like to use the iPod mode.
thanks
kiran
  • 32 Answers
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
Posted on Dec 26, 2008
  • 3 more comments
  • A Robinson Aug 28, 2010
    Thank you! Thank you! Thank you! I was ready to go to the store and buy new unit (as this one is now "old") but after taking the over off I found that not only were the discs dislodged, but one was actually wedged inside the machine. Took them out, hooked it back up and GOOD AS NEW! :)
  • Felishamshaw May 08, 2011
    I have no DVDs in my player. I have been getting the init code but was able to use the radio. Now I have this exact same sequence as the above poster and their is nothing in the player. I can't find anything online about the meaning of the HO 1 error or anything that isn't jibberish about how to realign the tray.
  • Brett Havener May 09, 2011
    I think it might be H: Hardware 01: Error number one, something physically stopping the motor that spins the trays around. Just a guess.
    In any case, if you don't get anything out after flipping the thing upside down and moving it around fairly forcefully with your hands about 5 times(5 iterations of the above 1-3 steps), then you could open it up and see what's inside. That's what I'd do, either that or just get a new one. This beast likes to get a couple of DVD's jammed against each other inside.
  • ego Nov 24, 2011
    I have no DVDs in my player. I have been getting the init code and im not able to use the radio. Now I have this exact same sequence as the above poster and their is nothing in the player.
    New Friend:
I have same problem help this solution is not helping
Posted on Dec 04, 2015
How do I open the dvd tray
is there not a small button on the laptop.
Feb 12, 2015 | Acer Computers & Internet
External DVD rewriter with trapped disk
Straighten a paper clip and insert it into a tiny hole in the face if the disc tray. Push the paper clip gently in the hole and the tray will pop out slightly. Then grab the tray and pull it out until you can remove the DVD disc.
Oct 12, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Dvd is jammed in the disk tray, will not let me change input to anything other than reading the dvd and giving me an error message.
To open the disk tray, take a paper clip and unwind enough of it to push through the hole located underneaht the tray. This should unlock it
Aug 23, 2009 | Audio Players & Recorders
HO1 error showing up on my panasonic dvd player,how do i fix it
Mode switch, plunger, or capstan motor defective
Apr 16, 2009 | Televison & Video
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
SONY DVP- NC85H
I am getting this error too and I believe it means that somehow the tray that the discs ride on is jammed. I think if you unscrew the three screws on the back and the two on the sides you can pop the top off and see the tray. I bet there is a disc somewhere that didn't fall back into its right spot and it will give you that error... I just opened mine up and sure enough there was a DVD that was in the way... I removed that disc and the error went away. I hope that helps you out as well.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Panasonic SC-HT740 System Logo
1,511 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
