Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ktichenaid, freezer on top
Kitchenaid, top freezer, 5 yrs old. Fan is working...freezer & refrigerator not cooling at all. The power circuit was triped off. Turned it on still doesn't work...Help in Hawaii
  • Anonymous Mar 31, 2014
    Freezer works, but not cooling, no fan turning
  • 120 Answers
Make sure your compressor is running if is not and and is just humming then is just your overload since you had a power outage it might off tripped it just repl and try that
Posted on Nov 03, 2008
KSBP25FJSS01 refrig too warm, freezer working properly but fridge not cooling like it used to. 8 yrs old
Be sure it is not overfilled. There is a circulation fan in the refrigerator compartment that if it is not operating properly or blocked, will cause what you describe.
Good Luck,
Gilsh
Nov 29, 2009 | KitchenAid KSBP25IN Side by Side...
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Freezer seems to be working fine but fridge is not cold... fridge is on top of freezer, it is a frost free zanussi, not sure which model thou, just coming up to 5 yrs old ? any help would be great thanks
A fan controlled by a thermostat is required to move the cold air from the freezer to the refrigerator for cooling. Use a volt meter testing the voltage on the fan. If you have voltage it is a bad fan. If you do not get a voltage test the thermostat. If it measures zero ohms short the thermal switch or if it is a short open one lead. If the fan works replace the thermal switch.
Sep 01, 2009 | Blueair Freezers
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
KA KSRS series lost cooling in refrig only
Check for frost accumulation in freezer or no freezer fan
Jan 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Side by side refrigerator section is not cooling the freezer is over cooling
SINCE THE FRESH FOOD SECTION GETS ITS COOLING BY AIR CIRCULATION FROM THE FREEZER, THERE MUST BE A RESTRICTION IN AIR FLOW SOMEWHERE. CHECK THE FREEZER EVAPORATOR AND FAN TO BE SURE THAT THE FAN IS RUNNING, AND THE EVAPORATOR IS NOT RESTRICTED WITH FROST. CHECK THE DAMPER OPENINGS FROM THE FREEZER SIDE TO BE SURE THEY AREN'T ICED OVER. IF IT IS AN ELECTRONIC CONTROL, CHECK THE THERMISTOR CIRCUIT FOR PROPER RESISTANCE. TECH SHEET INSTALLED BEHIND THE TOE PLATE SHOULD GIVE THAT INFORMATION.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
203 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
