Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 error #1203
    Master:
    Sergeant:
  • 461 Answers
This may be due to communication issue. Below link may be able to help you to resolve this issue..
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
Posted on Nov 01, 2008
  • 32 Answers
Hi
Error 1203 is either when a cartridge is dirty or damaged ...... Try cleaning the copper on the ink cartridge and cart slot in the printer and try again.
thanks
4 Suggested Answers
rasadam
  • 5 Answers
SOURCE: x4270 lexmark all-in-one InkJet Printer
Error 1203 is a bit of a generic cartridge issue. If this is a new printer and these are new cartridges, the most likely cause is defective cartridges, they do happen from time to time with new printers. It is also possible that there's a communication issue in the cartridge bay in your printer. Personally, I wouldn't try to do these diagnosing steps (Short of checking for any obvious mistakes). Since this printer is brand new, I would put it back in the box and return it for an immediate replacement. Some retailers would try to find any way to discredit your return right, the aim would be to give them as little ammunition as possible. To try and self troubleshoot the cartridge, first make sure they are inserted correctly. First, ensure you removed the tape from the contacts on the cartridge from its package. Make sure when you snap the cartridge in, it doesn't appear loose or easy to shake in the cradle. If you're still getting the error, remove the cartridge and check for any residual ink. If ink is present (appearing to leak in any form), it's possible this is causing the error. You can try cleaning the cartridge, a safe solution to use would be a light application of methylated spirits on a cloth that doesn't disintegrate. Holding the cartridge at its sides, you can run the cartridge in a vertical motion on the cloth. Horizontal motions can potentially damage the cartridge. You can also check the contacts on the printer (This is, the gold circuits where the cartridge touches the printer in the cradle). If ink appears on this, this can also be causing the issue. You would need to use an electrical safe contact cleaner (A very light amount) and a safe cloth to clean it with. Anything that can leave particles would be unsafe to use. Make sure to let the solution dry before reinserting the cartridge. Hope everything works out.
Posted on Jan 24, 2007
  • 3 Answers
SOURCE: Lexmark 4200 Series printer/fax
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Posted on Mar 20, 2008
Roop1980
  • 228 Answers
SOURCE: Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 23, 2009
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have an error message #1203. What do I need to do?
The 1203 error indicates a problem in either one of your cartridges or between one of the cartridges and the printer. This article will help you determine the cause of the problem and how to resolve it: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers.
Apr 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
THE DISPLAY SCREEN IS SHOWING ERROR #1203
The 1203 error indicates there is a problem with one of the cartridges. You may refer to this article to determine the cause of the problem and find a resolution: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers.
Apr 04, 2011 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK SERIE X4270 Error #1203
The best way to overcome this problem is to re-install driver.
You can download Lexmark X4270 All-In-One InkJet Printer driver PC Notebook From Following Link..
Jan 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
I keep on getting error # 1203 what does this mean?
Error 1203 indicates a problem with one of your cartridges. Refer to this article from the Lexmark website on How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
Ive a lexmark x4270 tried to copy says consult user guide for error #1203 and i dont have a users guide. anyone know what i need?
The error #1203 on the Lexmark X4270 indicates a problem with one of the ink cartridges. You can try to check this link - http://bit.ly/ckmSbC - for the steps that will help you resolve the problem. If it still the small I would suggest contacting Lexmark Technical Support. Thanks.
Aug 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
My lexmark all in one is stating error#1203 how do i fix the problem its a x4270 machine i was getting a fax and next thing i knowed was fax did not come thru and error#1203 poped up
Here's an article in the Lexmark website that will guide you on what to do when have Error 1203 on the printer. Just click on this link: http://bit.ly/ax8swM. Make sure to follow the instructions carefully. But if all else fails, I suggest you contact Lexmark at 1-800-LEXMARK (1-800-539-6275).
Apr 29, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
204 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
