Question about GE GDS18LBR Bottom Freezer Refrigerator
Condensor fan not running
Refrigirator was not cooling ,evaparator fan ran on and off,evap door ran on and off , mother board was clicking I replaced . Now everything works fine except the condensor fan is not running.Is this a fan issue or a temp board how do I check this. There does not seem to be correct votage at fan what should that be. Thanks jon
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Put your hand on the body and feel if it hot if hot change fan if cool problem
Posted on Apr 03, 2009
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
My compressor cooling fan quit- the compressor still runs. I unplugged the unit then plugged it back in. The cooling fan ran for about 15 seconds, then shut off again. Is the problem with the main control...
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Jun 23, 2010 | KitchenAid Superba Architect KSCS25INSS...
Condensor fan motor starts, evap motor tries to start, compressor tries to start but then the relays on the mother board begin to click on-off-on. Should the start relay be normally closed when the...
1. GE is replacing many defective boards free of charge. Check with them to see if you are qualified.
2.The start relay should be closed when refrigerator is de-energized.
3. Still a possible bad compressor or compressor start components. Test performed by service tech on compressor is usually done with a starting test cord. Would answer many questions quickly.
Oct 30, 2009 | GE Refrigerators
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Feb 21, 2009 | GE GSH25JFR Side by Side Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
123 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
