Washing machine won't agitate.
Maytag toploader won't agitate. i can't figure out what makes it agitate ? the belt is loose and smokes and builds heat when running. it spins ok and dumps water ok even though that belt is in poor shape. what makes the agitator go side to side? is it the water from the pump? is it possible with loose belt the pumps not creating enough pressure to move the agitator? i am a guru myself, but not on washing machines.
  • 93 Answers
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Posted on Nov 01, 2008
Maytag A512. Screeching noise smokes. Belts replaced, water pumps fine, spins. It does not agitate but the agitator is fine. Not stripped. What other problems? Transmission? parts to fix it?
The agitator shaft, not the agitator, is corroded and does not move freely.Smoke is the overheated belts, you need a transmission overhaul, boot seal and tub bearing as well as replacing the agitator shaft, again, NOT the agitator.
Jun 06, 2017 | Maytag Washing Machines
How to repair a loose drum?
You need to remove the agitator, loosen the tub nut (May already be loose), align bowl & tighten tub nut.
Mar 16, 2015 | Maytag Washing Machines
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Maytag quiet series 100 stopped midcycle, smells a little bit of smoke
sounds like a burned belt, once the belt is burned from being loose, the burnt spot gets hard and the pulley will not catch to make the machine run , replace the belt.
Sep 16, 2013 | Maytag Washing Machines
The howling (squealing) noise is likely the belt, if I had to make an educated guess. Of all the fixes you could be stuck with, that's one of the easier ones.
The reason I suggest that is because even though it probably isn't washing to its fullest potential either, you wouldn't really notice it, if it's still able to do a little agitation. Once the spin cycle kicks on, the motor applies a lot of power, and if the belt is loose, it'll spin that belt around the wheel, creating a really soothing and serene squealing noise, causing average humans to start seeking sharp objects with which to slice their wrists.
Sep 02, 2012 | Maytag Washing Machines
Older topload maytag won't agitate , smells like burning belt
Best to look at replacing belt, but first check to make sure nothing is seized, drum spins freely etc.
Jul 23, 2011 | Washing Machines
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Replaced belt but machine will not agitate or spin , but does let water in it
if it is a topload u have a bad transmission thats what broke the belt was trying to spin and couldnt
Apr 16, 2009 | Washing Machines
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Washing Machines Logo
257 people viewed this question
Top Washing Machines Experts
