Acer Aspire 5630 Hi there, I had to completely wipe hard drive due to a really nasty virus, have installed wndows XP, but have no drivers to run my laptop. I have a recovery disc from when i bought it, but haven't a clue how to install drivers or what drivers i am looking for. Please help!!! Damsel in distress x
  • 32 Answers
Hi
Here is a list of drivers needed (pdf format):
http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
and here is where you can download all drivers.... find under drivers and utilites:
http://support.acer-euro.com/drivers/notebook/as_5630.html
hope that helps!
Posted on Nov 01, 2008
Hey I did a clean wipe of my paritioned drives and replaced the standard vista with XP professional. Everything went smoothly until I found out that my ethernet controller driver is missing and i...
The link below is to a buddy of mine and this site has many drivers for XP that will work on systems that have been refitted from Vista. Just scroll down through the page and you will come upon drivers for wired ethernet as well as all other devices that have issues.
http://www.tim.id.au/blog/tims-free-for-all-driver-guide/
Aug 11, 2010 | Acer Aspire 5630 Notebook
Hi, I want to reinstal the system in Acer 5630, there is a button starting all proces when laptop starts.. whihone?
You probably need to go into the system bios at startup and under advanced options you need to set your system boot up devices. You should set the 1st option to the CDrom and the 2nd option to your hard drive. Then when you put a windows or restore system CD in your laptop it will boot up there before going into Windows. This should start the Windows installation process. Be advised to backup any files you want to save before doing this as Windows wants you to format your hard drive at the start of the installation process and will wipe your hard drive clean. Good luck!!
Nov 22, 2009 | Acer Aspire 5630 Notebook
Need to factor reset,|NOT REBOOT, for acer aspire 3630 windows xp
Hi and welcome to Fixya..
Reinstalling Windows XP on an Acer Aspire 3000 is fairly straightforward. You may need to reinstall Windows XP due to hardware failure, a virus infection, major hardware changes or a hard drive upgrade. Whatever the reason, you can do the reinstall yourself at home. The reinstall will take anywhere from 1 1/2 to 3 hours, depending on the size of your hard drive. Be aware that reinstalling Windows XP will format your hard drive, getting rid of all data on, so you'll want to back it all up on a media device.
  • Step 1
Back up all data on your computer before reinstalling.
  • Step 2 Insert the Windows XP disk and restart your computer.
  • Step 3 Press any key when prompted to begin running the disk.
  • Step 4 Press F8 to agree to the terms of service.
  • Step 5 Choose the partition you want to reinstall Windows XP on. This is usually "C:" for most users.
  • Step 6 Choose the type of format. You can choose either "Quick" or "Full" for NTFS systems. A quick format only takes a few minutes less than the full format.
  • Step 7 Wait for the format to complete. The Windows XP installation wizard will begin. You will be asked to choose your time zone, computer name, and to input any network information. Otherwise, the reinstall will run by itself.
  • I hope this helps
    Oct 15, 2009 | Acer Computers & Internet
    Acer 5630 (Windows XP) screen flickers
    This is due to your graphic driver. Reinstall your graphic driver will fix the problem.
    Jun 07, 2009 | Acer Aspire 5630 Notebook
    My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
    I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
    Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
    So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
    Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
    Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
    Web camera is not working
    Here you go:
    1. Press ‘Alt + F10' to start eRecovery Management.
    2. Enter default password of 6 zero's. Example: 000000
      Select ‘Recovery Actions' and click ‘Next'
    3. Select ‘Reinstall Applications/drivers' and click ‘Next'
    4. On the left hand side of the newly opened window select the following: Windows XP
      ? Driver
      ?Camera
    5. On the right side of the same window, click ‘Install Camera Driver Now'
    6. The unit will reboot after the installation is complete.
    Please rate my solution when possible....!
    Good Luck....!
    Cheers
    Jun 14, 2008 | Acer Aspire 5630 Notebook
    Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
    You have to integrate the SATA AHCI driver to your windows XP CD. By doing this you will be able to install the OS. The process of integration is given in the link below:
    http://techrena.blogspot.com/2008/10/how-to-install-your-own-wndows-xp-in-hp.html
    They have given a detailed description in the site.Hope this will work.
    May 15, 2008 | Acer Aspire 5610-4648 Notebook
    Laptop Volume
    Dear Lozzer89,
    Please let me know the Brand and Model of your Notebook, so that i can provide you the right link for the same , to download the proper drivers for the same.
    Cheerup and Be Happy always
    Mar 04, 2008 | Acer Aspire 5630 Notebook
    Acer Battery Power
    may be this is an attack by some harmful viruses . i too experienced blue screens due to virus attack . downlaod avast proffesionl edition and install it (latest version availabel on katz.cd ) and scan computer at boot time ( avast only provides boot up scan ). otherwisw think of installing a fresh copy
    Dec 03, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
    Computers & Internet Logo
    52 people viewed this question
    David Payne
    David Payne
