Question about Hotpoint Aquarius WF000 Front Load Washer
Wf000 aquarius hi i have a hotpoint wf000 it has started making a grinding noise even when you turn the drum by hand like something rubbing can you help
  • 244 Answers
If the drum moves slightly up and down then your bearings are in need of replacing u can also check this by going to the back and taking the little cover of in the centre of the back check around the centre of the spider wheel if there is a mucky water mark then they do need replacing this will cost from £90-£150 to replace love
Posted on Nov 13, 2008
Dear fixya, I have a hotpoint aquarius wma52 which sounds like it grinds when drum turns. I gather it may be the bearing but I don't see how to take off the back and check to replace.thankyou
First of all, is the noise only heard when the drum is rotating or when the pump is running? This really makes the difference. Sometimes an object can rub on the outer tub during rotation and cause the same noise, other times, I have found foreign object within the pump and caused the same problem. So when is the noise heard is very important to lead you in the correct direction.
I will be glad to assist you if you like
Jul 28, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When washer is on spin mode there is a very loud grinding noise and when i check the inside to see if anything left in when wash has finish i turn the drum and the grinding noise is there.Please can anyone...
Take the backplate off the machine and take out the heating element which looks like a long oval and has three wires to it you can then see inside the drum to see if anything is in there
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes grinding noise when turning
spin the drum by hand, if it feels rough or is noisy, then you probably have drum bearing failure.
Another possibility is one or more of the drum paddles may have come adrift..
These can be replaced.
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
327 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
