Question about Frigidaire FEF352 Electric Kitchen Range
Fridgidaire oven The top element and bulb for my oven needs to be replaced. I am looking for the part #'s.
  • pitman5050 Nov 09, 2008
    light is out inside stove
Light out inside stove
Posted on Nov 09, 2008
Oven bake element does not work after replacing fridgidaire
it could have a burned off terminal on the element(not likely as you saw them during new element install) or it could be a defective relay on the control board where you set the oven temperature,one side of the element is always at 120 volts from the power cord,the other side of the element is controlled on and off by the control board
Nov 28, 2012 | Frigidaire Ovens
Fridgedaire Oven burner sometimes doesn't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Dec 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
The oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Aug 05, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Nov 12, 2007 | Kitchen Ranges
Frigidaire FEF352 Electric Kitchen Range Logo
60 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
