Question about Husqvarna Chain Saw 20" Bar
Chain oiler i own a 272xp, does it have an adjustable oiler or is it fixed?
  • bgrinaldi Nov 02, 2008
    thank you for your help! oiler was still working but not as effective as i thought it should have been. thanks again!
    Problem Solver:
  • 13 Answers
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Posted on Nov 02, 2008
  • maple flats Nov 02, 2008
    Sometimes you can get sawdust into the oil reservoir and it gets into the oiler tube, plugging it. I am not sure how the 272XP would clean. I think that one is a gear driven pump, might need replacement.
Replacing a chain adjuster on 272XP Husqvarna.Sheared the bolt. Purchased the correct part.I cant make out how to put the plastic adjusting nut on the screw from pic in the manual.Lil help? thank you!
The square nut should slide into the housing to stop it from rotating. The nipple end should also fit into the case behind the protector plate.
Dec 02, 2016 | Husqvarna Garden
How do I just how much oil comes out an automatic Oiler
It depends what make and model. But you haven't stated. Some oilers are adjustable, others are fixed.
Apr 13, 2016 | Garden
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
? 6:38
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Where is the adjustment for chain oiler?
depending on the saw it may or may not have one. most home owner saws are not available with an adjustable oiler. if however you are sure it has one it is accessed via the bottom of the saw on the clutch side
Feb 10, 2013 | Garden
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 340 oiler not working
Hello again Rudy.
Please reply below (Add Comments) with the serial number of your saw then I can investigate a little further.
You can reply even when the question is closed. I am not certain how but I get email notification of your reply when done correctly. If equipped the oiler adjustment is below the crankshaft on the clutch side. Look up from the bottom. On the side of my 359 is an icon of a link of chain with a drop of oil above it. The oiler adjustment is aft of that and can only be seen from the bottom of the saw. The manual I saw said 3 position only with CCW (3 - 18 to 20" bar) most oil. Forcing it beyond the stops causes a lot of problems.
Page 36
Is your serial number is between 07 18##### and 08 17#####?
Page 5 item 1 shows location of the serial number. Not all newer saws have an adjustable oiler. Please reply below.
Dec 18, 2009 | Husqvarna Garden
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Husqvarna Chain Saw 20" Bar Logo
464 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
