Question about Insignia Digital-to-Analog Converter for Analog TVs
Insignia Converter fails to display menu on TV
We're unable to get a menu display after we've hooked up our Insignia to our old TV. The instructions don't seem to address the "no menu" problem, so anyone have any ideas?
We did install the wire-to-coax adapter for VHF, do we need to do this for UHF as well?
Thanks in advance.
JPP
kcav8r@hotmail.com
  • kcav8r Nov 18, 2008
    Thanks for your suggestion. The set and converter are about 60 miles away from me at our cabin, so I'll tinker with it some more next time I go there. My other Insignia (at my home) installed perfectly first time, so I'm thinking I've got a bad converter. I may just drag the suspect converter home and see if I can get it to work on one of my other TV's.
    Thanks again for taking the time to respond!
    JPP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Do you get reception at all? If you've tried all the buttons on the remote and can't get a menu to show up maybe there's technical problem and you need a new machine.
Posted on Nov 17, 2008
Hi! My mother gave me an Insignia HDMI TV, and I can't figure out how to hook either my Wii console or Sony DVD player to the TV. I transfered all of the audio/visual cables from the old TV to the new TV...
Hey there!
Is there a button on the set or remote that says "input" or "source"? That will change the input settings from cable, to HDMI or RCA (aux).
Mar 08, 2011 | Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Box was working, tv now back to analog
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Jun 18, 2009 | Insignia Digital-to-Analog Converter for...
I hooked up the converter box to my antenna and TV, turned both on, but never got the Welcome window and menu to set the thing up, that the instruction book said I should get. All I got was "no signal."...
I don't know what converter box you have, but try these steps to see if they work:
1. Turn on your TV to channel 3 or 4.
2. Turn on your converter box.
3. On your converter's remote contro, press menu key.
4. A list of menu items appear. You can autoscan channel from there.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Jun 02, 2009 | Insignia Digital-to-Analog Converter for...
Problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-LCD32 TV
The tuner section, and or the voltage regulator circuit that supplies it is probably failing. The service rep for your set may be able to order a new tuner module and install it. This is not a type of repair you can do yourself.
Jerry G.
Jun 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia Digital-to-Analog Converter for Analog TVs Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
