Question about Samsung WF337AA Front Load Washer
Fault code 5E
Machine will not finish its program and displays error code 5E or SE
  • Anonymous Mar 17, 2014
    error code 5E
  • Anonymous Mar 19, 2014
    ERROR CODE FLASHING SE OR 5E MACHINE HAS STOPPED CANNOT OPEN DOOR
  • 43 Answers
Possible pump problem
try cleaning out the filter
Posted on Nov 10, 2008
Here is the 5E fix for samsung washer/dryer. When the washer has been moved a rubber pipe has pulled apart. It takes 10 minutes to fix. Just take off the back panel, it's only 4 screws. Ensure power is off and cord unplugged, of course.When panel is off you will see the black rubber tube about 3 inches round, about one third of the way down from top on your left side. It comes from the drum and the other end needs to be replaced over the clear/white plastic ring mounted next to it on the left side wall. Mine hasn't even got a clamp, so I just pushed it on.
Everything in the machine now works 100% perfectly. It took me 4 very frustrating months of constant 5E warnings, before I discovered this. So give it a try, it was the answer for me.
Steve H.
Posted on Mar 11, 2011
Hello i have LG washer 7 kg when the motor work a few minute the display show SE if i press switch start his continue normal and repeat this state after any time
@Mowafak
"LG 7Kg SE error...."
Hello M,
The error is 5E not SE.
They look the same on a digital display :)
This is a "Water not draining out" problem.
The machine detects level of water while draining.
If this does not drain in a 15 minute time-out, error 5 "5E" pops up on the digital time display.
Somewhere in the draining path, there is blockage.
Try this:
Check your drain hose for blockages, and that it is installed the correct way.
Remove the drain hose - prepare for a possible flood from the machine drain if you do this!
Use a garden hosepipe or strong pressure tap to flush hose forward and reverse until water runs clear.
If you live in a very cold climate maybe the hose is iced up inside.
Also check all filters to see they are not blocked up.
Hope this helps,
Clive.
Oct 18, 2017 | LG Washing Machines
I have an LG WM-12230FB and it is showing error code 5E. there is no reference to this code in the manual. Any ideas?? Many Thanks
I believe that when 5e is displayed it means to check the debris filter which is usually located at the bottom right hand side of washer and don't forget to drain the washer first!
Also, is there anything that would suggest the machine is otherwise not running properly?
I would also try to reset it by unplugging it or tripping the circuit breaker.
Let me know if you need more help and I would be glad to assist you further with this.
thank you
Apr 27, 2008 | Washing Machines
My machine is showing se
SE also comes up as 5e
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error.
You can perform following steps to resolve the issue :
? Clean the debris filter.
? Make sure the drain hose is not clogged.To make it unclogged, Detach the drain hose from washing machine. Attach the spray nozzle to the end of the hose. Aim the sprayer into the clogged washer hose and spray water kinetically down the hose. Continue spraying until the hose is no longer clogged.
? Make sure the drain hose is not frozen.
? Make sure the drain hose is installed correctly.
Dec 16, 2016 | Washing Machines
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
Mar 28, 2010 | LG Washing Machines
Machine wont complete cycles and SE showing on display
This is likely a 5E error code and refer to your owners manual for cleaning out the filter coin trap as there is likely debris in it.
May 14, 2009 | Samsung Washing Machines
Samsung WF337AA Front Load Washer Logo
1,295 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
