Question about Briggs & Stratton Electrical Supplies
'Get-Jet' Airplane mover
I don't have a spark at all. I've ordered a new coil, hoping this will fix the problem. Does anybody have any information that could help me, such as a wiring diagram for the ignition circuit, or any suggestion. It's an 8HP Briggs and Stratton engine.
Cheers, Freddie M.
  • 211 Answers
Hi Freddie ignition- to- flyweel gap means flyweel magnet positioned under the ignition coil armature.Remove the flyweel.Check the flyweel key(if it is sheared off install a new one).Remove the ignition coil.Clean the flyweel magnet and the ignition coil armature.Check the ignition coil wires and terminal to have continuity.Remove the breaker points cover,check the condenser and breaker points(they should not to be burned).The ignition breaker point gap and ignition-to-flyweel gap is 0.020" and the spark plug gap is 0.030". regards savumihai71
Posted on Dec 13, 2008
Peugeot Jetforce 50 no spark.
Hi, Steve and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Peugeot jet force 50cc No spark
Peugeot Speedfight fix part 7 no spark Cdi unit chat review mark savage
https://scootergrisen.dk/scooterhjemmeside/download/peugeot_jetforce_servicemanual.pdf
Peugeot JET FORCE 50 cc 2003 Parts
PEUGEOT JETForce Technical Training Manual
Aug 24, 2017 | Peugeot Motorcycles
Have a Peugeot Jet Force 125 and it turns over but no spark in plugs
Hi, Don and the usual suspects are:
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GY6 Electrical Troubleshooting Tutorial No Spark Eliminator
Peugeot JET FORCE 125 cc 2003 Parts
May 21, 2017 | Peugeot Motorcycles
Hi got a sym jet 4 rode it parked it up and now no spark at all help please is this a comon thing 2014 plate to
Hi, Ben and the usual suspects are:
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
no spark at all on 50cc sym jet euro sport Scooter Doc Forum
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
Sym Jet 50 Service Manual
SYM JET 50 Spares Parts Accessories
SYM Fiddle II 125 AW12W Service Manual
SYM JOYRIDE 125 User Manual
Jan 16, 2017 | Sym Motorcycles
Do you need a type rating to fly your own Bitchcraft 1900 or Cessna CJ2?
The type rating is required in aircraft that need additional training. It is a safety of flight issue not a for hire issue.
Jan 04, 2017 | Aircrafts
I put on a new coil and trigger unit had spark for 4 minutes then no spark at all
coils are differend and have you ordered with the serial number of the coil that is used then there must also modificated a flywheel there are modifications that the coil will not work on the old flywheel or the coil was overloaded ??. and no part of stop wire hangs on mass.
If you not certain about you don,t know that this can happen then you dealer knows this for shure.
Hope for you that was only a problem of dirt on the bougie remove the bougie take a metal piece and hold it near a metal place like the cilinder it must be sparking the collor of the spark must me white blue (not red)
Dec 02, 2015 | Garden
Just serviced my legacy b4. Had to take the battery off to get to coils, checked these and theyre working. Idols roughly. Coughs also. No power when tried to drive. Any ideas please?
Thank you for the inquiry.
Sounds like you may have a non-connection on one of your spark plug wires or the ignition coils. Certainly would explain the lack of power and and rough idling or running.
You will also want to confirm you haven't rotated any wires. See illustration for firing order: 92759554.gif
u897911942mtp.qkt u6999881634srg.qkt
I hope we've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response.
I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Best regards,
TF
Jun 03, 2011 | 1999 Subaru Legacy
It cranks but wont start. Checked for spark with the lead plug wire from the coil to the distributor cap. No spark. I changed the coil still no spark. I've been told its my fuel pump. But I've...
if you are sure there is no spark and you have replaced the coil,then the only other thing it could be is your spark control moduel.it works off your computer to tell your plugs when to fire..somettimes they go out only when they heat up and will start working again after they cool down,,but sometime they don"t give you any warning and just stop working all together.. would say you have a bad Spark Control Moduel.....it is pretty easy to fix, just make sure you use or buy the right tools to take it off , ask at the Auto parts store to get the right tool, and the right part..
May 26, 2011 | 1988 Honda Prelude
Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
Sep 12, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Electrical Supplies Logo
313 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
