Question about Toro Electric Power Sweep Electric Blower
Leaf blower is loud and motor not set in correctly.
Makes loud noise and smells electrical
  • jordan4010 Nov 01, 2008
    New email address jordan4010@mchsi.com
    Scholar:
  • 62 Answers
Sounds like the brushes on the motor are bad. Sorry, but this is not repairable. It could also be that the motor is not secured to it's support housing, but I would have to see it in person to make this determination. Electric leaf blowers are not made to be repaired, because it's usually cheaper to buy a new one. I know this is probably not what you wanted to hear. However.....since it is probably junked anyway, it's not going to hurt one bit to try and take it apart and tinker with it to see if there is an obvious problem. Just pay attention to how it comes apart, in case you want to put it back together. Hope this helps,
Chad
Posted on Nov 01, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dewalt D55146 makes loud leaf blower noise, has a burning smell and doesnt build pressure
This compressor is belt driven. When the belt fails the motor will run faster than normal and takes longer to stop turning. When belt is in place and the motor is shut off, the motor will stop almost instantly. If the belt is slipping, you will smell rubber burning (you will need to change the belt anyway). It is my opinion that the belt fails because the cut-off pressure is much to high (200psi). The belt will last longer is the pressure switch cut-out at a normal 125psi. If the discharge tube (tube from pump head to tank or in-tank check valve) or other parts are leaking, it will take much longer to fill and cause over-heating. You can keep track of the condition of the compressor internal parts by knowing how long it takes to fill the tank when new compared to how long it takes now. As parts wear, the unit will take longer to fill. Go to the dealer and time a new unit then test yours against this time period. Do not use an extension cord on this size compressor. Use more hose instead. If you are having trouble filling the tires because of low pressure in the hose, try experiment. Remove the safety valve from the compressor and install a tee fitting. One one port of the tee, reinstall the safety valve. On the second port install a quickconnect fitting. This will give you access to full tank pressure bypassing the regulator to quick fill your tractor tire. This trick is how the tire shop quickly fills a tire. Use caution and do not overfill your tire. Good luck
Apr 11, 2013 | Dewalt D55146 Heavy Duty 412Gallon 200PSI...
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
When i turn my heater on (and also the ac) it makes a loud humming noise. as i turn it higher the noise gets louder. I have a 2001 chevy trailblazer.
It is possible that a stray leaf or piece of debris is stuck in the blower fan blades. This is more likely if the noise began suddenly. You will have to access the blower and remove it to inspect the blades. If their isn't an obvious debris problem, the blower fan bearing may be wearing out and getting noisy; although this noise would slowly get worse and worse every day.
Jan 24, 2011 | Chevrolet Blazer Cars & Trucks
Blower motor makes some very loud noise on every setting im thinking its about done , it is 13 years old . Also how easy are they to change out?
it fairly easy, go to the passenger side under the glove box. there are some screws and an electrical plug, lose all that and remove the blower motor. you may find some leaves or trash in there! that's why it made noise
Feb 28, 2010 | 1999 Chevrolet Silverado 1500
Chevy tahoe 1999 heater making noise when I put it on hi loud noise how do i fix it
Remove blower motor and inspect could have leaf's or something in it, also check blower motor shaft make sure blower shaft bearing are good.
Dec 09, 2009 | 1999 Chevrolet Tahoe
My toro blower stopped working after only 10 minutes
Hi, normally when an electric motor smells of burning the damage is done, if it's new you need to get it fixed under warranty, trying to repair it yourself will void warranty
Aug 30, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
My blower motor makes loud noise on top settings
new motor by the sound of it ,but never worked on one so i couldnt tell you where it is,other than its no doubt a complete unit with the resistance so it will not be cheap
Nov 17, 2008 | 2002 Chrysler Sebring
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Toro Electric Power Sweep Electric Blower Logo
574 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
