Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint ultima washer dryer
Hi washing machine keeps coming up with msg check outlet pipes can you tell me how to do this please
  • 43 Answers
Ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Posted on Nov 12, 2008
Hi, i got a hotpoint ultima extra washer dryer, code WDM73, it does a wash but at the end of a cycle it wont drain the water, it says check the outlet pipe but theres nothing wrong with it, i dont have a...
try bottom front right hand side is a filter ,...undo ..water will come out so have some towels ready... clean and refit... bsc appliances 07779933829 spares and repairs.
Feb 27, 2011 | Hotpoint Washing Machines
Water coming from soap compartment. is there someway to clean the dryer fluff from machine
It sounds like the water outlet is blocked. Same happened to me.
Unplug machine from mains.
Remove panel located on the rear near the base of machine.
In the bottom right corner you will see the outlet pipe and the pump.
Remove grey outlet pipe to get better access.
Undo the large jubilee clip where the black pipe joins the drum outlet.
Inside this pipe is a white plastic cage filter.
Check to see if anything is blocking it.
Jan 07, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hi hotpoint 7kg washing machine ultima digit washes fine and spins etc but i keep getting f05 flashing on display what do i do
Hi there usually the FO5 Problem is pump draining problem, check the U Bend under your sink for blockages also the outlet pipe for blockages, you may even need to take of the front lower panel and you should find a small pipe and you can clear and drain water from that also and clear of any bits. hope this helps
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Outlet Pipe
Your machine has detected a problem with draining. The place to check is the filter located at rear of machine.To access it remove plate at bottom rear of machine & you will see a black pipe hanging vertically from the drum secured by a spring clip.The filter is in this pipe. If this is clear take off other end & check pump is not obstructed.Be aware that there will be water in these pipes so may be wise to take machine outside.Let me know if problem persists.
Nov 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Machine keeps stopping
if its right at beggining of wash could be pump blockage chack for coins or ffluff blocking filter
Nov 12, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
