Question about HP Compaq d530 PC Desktop
How do I remove cover panel to install a wireless PCI card on an HP d530
I have an MSI PC60G Wireless 11g Turbo G PCI card to install in an HP d530 mini-tower, but I don't know how to remove the cover panel on the PC to install the card.
  • 153 Answers
Usually there are knurled screws on the back that secures the side panel or a quick disconnect lever that releases the side panel. After removing the side panel, you will need to remove the screw that holds the cover over one of the PCI slots if there is one. Install the wireless card and press down hard to make sure the card is inserted all the way. You will probably have to insert the accompanying CD if the computer doesnt automatically load the driver.
Posted on Nov 01, 2008
  • 113 Answers
I don think so u can remove the front panel more over if u try there re chance it might get chipped, at the both the side u wud be having screws try unscrewing and u can take it out and u will be able to fix in the mother board
How to enable wireless networks on hp pavilion a6330f or does it need a wireless card and which and what type of card or PCI or USB? What is a PCI? How to install a wireless card?
See the link below for product specifications.The simple way to go is an external usb adapter for wireless, since your motherboard only has one PCI slot and it likely has a 56K modem installed in it. Remember to put the driver disk which comes with your adapter in the CDROM/DVD drive BEFORE you plug in the usb adapter , and follow the installation directions carefully - unrecognized usb devices can be difficult to remove...
HP Pavilion a6330f Desktop PC Product Specifications
Mar 14, 2015 | HP Computers & Internet
Does the dell studio 540 pc come with a built in wireless card
The wireless card was optional for that particular computer. You can see if you have one by clicking the start button (lower left corner) right click on computer and select "manage". When the window opens click device manager in the left window and find "network adapters" in the larger center window. If you see a wireless card listed in that then you have one and it should be activated already (there's no on/off switch for wireless on a desktop). If you don't, any PCI wireless card can be purchased for 15-30 bucks. To install it, turn off and unplug your computer, take off the side panel of your machine, remove the i/o cover adjacent to the PCI slot you plan to use and insert the card into the pci slot and secure it with the screw that held the cover on. Power on your computer and run the driver installation software that came with the card you purchased.
Jul 10, 2012 | Computers & Internet
Need to know what pci card to buy for a 830 gateway computer to make it wireless
Any Pci wireless card should do, although I'd go for a trusted make like Belkin, or Netgear. You basically want one with the following specification. (as an example)
http://www.ebuyer.com/product/50127
Jul 20, 2011 | Gateway 830GM PC Desktop
Error Message: 104-Unsupported wireless network device detected. System Halted. Remove device and restart.
I think you can try this steps and hope it will help you.
Try to reseat the Wireless Card in your machine.
You will need the following tools to complete the removal and replacement procedures:
-Magnetic screwdriver
-Phillips P0 screwdriver
-5.0-mm socket for system board screwlocks
-Flat-bladed screwdriver
-Tool kit-includes
Turn the machine upsidedown
Remove the battery.
Wireless Card Removal
1. Loosen the PM2.0×5.0 screw 1 that secures the Mini PCI
compartment cover to the computer.
2. Lift the rear edge of the Mini PCI compartment cover 2, and
then swing it forward.
3. Remove the Mini PCI compartment cover.
4. Disconnect the wireless antenna cables 1 from the Mini PCI
communications card.
5. Spread the two retaining tabs 2 that secure the Mini PCI
communications card to the communications compartment
socket. (The board rises up).
6. Remove the wireless communications card 3 by pulling the
board away from the socket at a 45-degree angle.
**Reverse the above procedure to install a Mini PCI
If happens that it does not work, I think you can just reinstall OS just to make sure if its Hardware or Software problem.
Thank you for choosing FixYa.
Apr 24, 2011 | HP Compaq Presario V2000 Notebook
I have a msi PC60G Wireless card but it doesn't seem to want to connect with my new Windows 7. What can I do?
Windows 7 should download the driver by itself, try to connect the pc to internet trough a wired connection and run windows update, then look in the "optional updates" and select the checkbox of the wireless card item. once downloaded windows shold install it alone. I hope you can make it work!
May 12, 2010 | MSI PC60G (MS-PC60G) Wireless Adapter
Need driver for msi pc60g-f wireless pci card
http://www.howtodrivers.com/model566113.html
Step-by-step guide for install MSI PC60G-F driver.
1. Download file for MSI PC60G-F from our site, save it on your computer and unzip.
2. Connect your MSI PC60G-F to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new MSI PC60G-F on Network adapters category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Msidriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new MSI PC60G-F in Network adapters inside device manager.
Aug 25, 2009 | Computers & Internet
Cheats of pirates of the caribbean at the worlds end
Hey,
heres a walkthrough
http://www.neoseeker.com/Games/Products/XBOX360/pirates_of_the_caribbean_at_worlds_end/faqs.html
this is for xbox360 let me know if you need another. I'm sure it will include how to put ladys in pots.
Thanks,
Ekse
Feb 25, 2009 | MSI PC60G (MS-PC60G) Wireless Adapter
MSI PC60G Wireless Adapter Driver for vista
Hi Salmar,
The driver can be found on the MSI site here:
http://www.msi.com/index.php?func=driverfile&dno=2284&i=1
Pick your region and download.
This covers both Vista 32bit and the 64bit operating system.
Run the install utility and let windows recognise, configure adn install it fo ryou.
Reboot and check the wireless operation.
Nick
Jan 06, 2009 | MSI PC60G (MS-PC60G) Wireless Adapter
HP Compaq d530 PC Desktop Logo
188 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
