Question about Code-Alarm Code Alarm Transponder
Ford fiesta transponder problem
I have ford fiesta diesel ghia 1998 model alarm started not to reconise the key the light was flashing quicky in the clock i only had one key so wasnt certain it was a key fault managed to get hold of the red key and the rest for the keys car fault sill present was wondering if it was a transponder fault round the barrel and how to check if it was and if i was able to get one from a breakers yard
I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
Thanks llinos
Posted on Aug 06, 2009
    Problem Solver:
  • 7 Answers
Hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, put key in ignition turn full, if nothing happens get out lock car n open it then it should work! (if u have remote cental locking use that not key in lock)
good luck!
Posted on Jan 01, 2009
  • Ford Master
  • 22,326 Answers
No chance as its the reader unit that reads the coil around teh key,either by pass the immobiliser or take vehicle to ford and havve the keys re set.by-passing the immobiliser is no big deal 20mins work but it means that any prospective boy can racer can half inch your dearly beloved jam jar
Posted on Nov 22, 2008
How to bypass alarm system lost the remote 02 ford expedition
Factory alarm is Passive. Passive Anti-Theft System. It is a transponder chip in the key and a transceiver ring around the lock cylinder. If the alarm starts go off when set and not unlocked with remote or key, inserting the programmed key into the ignition and starting will disarm the system, shut off the horn and flashing lights and allow the vehicle to start.
Mar 07, 2017 | Ford Cars & Trucks
How can I reset the service warning on a 2011 Ford Fiesta Diesel
Turn the key on, press the fuel pedal three times,slowly, within five seconds. the light should flash. When it stops turn the key off. This should reset it.
Oct 25, 2014 | 2011 Ford Fiesta
00 ford fiesta,, heaters,electric windows and indicators not workin, fuses and relays seem good??
have exact same problem myself checked all fuses they are fine & my car is a ford fiesta yr 2000 model Ghia gonna have a look at the 50amp fuses
Any1 else out there have a possible solution. If this 1 dont work
Dec 22, 2009 | 2000 Ford Focus
Central locking not working
Assuming that the battery mentioned above is the Key Fob battery?
The usual solution to the key fob not working the Central Locking after battery replacent  is to remove the car battery feed fuse   to the Central Locking (or disconnect the car battery )  for 10 minutes...replace it..... then it should work OK
note: If you disconnect the Car Battery then make sure you have the radio security code.
If not then POST A NEW QUESTION quoting your radio Serial Number (usually begins with M * * * *  * * )
Sep 25, 2009 | Code-Alarm Code Alarm Transponder
1998 Ford F-150 won't start w/ the key, but will w/ remote start.
Always verify that there are no aftermarket devices causing interference, such as alarms, remote starters or other devices utilizing transponders. Devices that power up the PCM without powering up the PATS Control module can experience no-start concerns. It is probbally a key issue depending on the PATS system in that truck you may have to have more than one key coded into the transponder. Try you spare key.
Jul 09, 2009 | Ford F-150 Cars & Trucks
Radio code needed
The radio will have to be removed from the car dashboard .Then please quote the SERIAL NUMBER...usually beginning with M + + + + + +
Apr 05, 2009 | Code-Alarm Code Alarm Transponder
How do i change clock om ford focus ghia 05
this maybe able to help you if no owners manual to find one online at www.edmonds.com
Mar 31, 2009 | 2005 Ford Focus
Code-Alarm Code Alarm  Transponder Logo
1,907 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
