Question about Kenmore Elite HE4 Electric Dryer
Problem with Kenmore Dryer HE2
I have a 1-year old dryer Kenmore HE2. Recently I found that drying time has increased and it jumps. For example, display shows that 10 min left to the end of the cycle and after this time expires it may show 17 more min. I checked ventilation system and found no blockage. Screen is also clean. Can you help me to identified this problem?
  • edensmom999 Nov 19, 2008
    Same issue everything is clean , could it be a bad sensor
  • tanddcolton Dec 11, 2008
    Drying time keeps setting itself back. Display just shows 99
    Sergeant:
    Champion:
  • 324 Answers
Have you gotten any error codes?
Posted on Nov 05, 2008
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
I have a Kenmore dryer with Model # 110.C67711600 and Sr. # MU2206156. It is 2 years old and all of a sudden, dryer stopped drying. Clothes remain damp and wet even after running the dryer for 60-70...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Jan 02, 2011 | Kenmore 62622 Electric Dryer
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
I have a 30 year od (Sears) Kenmore Dryer and just
Haven't found a solution nor any help. The only thing I saw was an ad to "upgrade" for a fee to get assistance
Dec 29, 2009 | Kenmore Dryers
Takes too long to dry
Check the following ares carefully to combat this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 18, 2009 | Kenmore 63942 Dryer
I have a Kenmore Elite HE3 gas dryer. The dryer worked great. And then we moved to a new house. We had to have a gas line installed for the washer and dryer. Ever since we've been in the new house the...
The first thing to do is check the venting from the back of the dryer to the outside of the house including the venthood make sure it is clear. Blocked airflow can increase dry time decrease efficiency.
Dec 30, 2008 | Dryers
Dryer isn't working
I had success.  I found the manual....unplugged the dryer, and rotated the inside drum several times to check for any coins or small objects.  I did not find anyything, but if something small was lodged it is not hampering the dryer.  I plugged it back in and it worked right away...
lizzardhips
Oct 26, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer takes too long to dry clothes. it usually takes two complete cycles to dry . ( dryer is a kenmore approx. 3 years old, but out of warranty
this is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 16, 2008 | Dryers
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
548 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
