Question about Kenmore 22622 Top Load Washer
Won't drain, rinse, or spin
Kenmore 22622, will fill with water and agitate on all settings (normal, heavy duty, and delicate) but when the timer reaches the point when it should drain, rinse, and spin it just quits.
How do i get the top off to replace the safety switch
Posted on Feb 24, 2009
  • 93 Answers
That will be a lid switch problem
Posted on Nov 01, 2008
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washing machine stops after wash agitation cycle and does not drain. Timer also stops ticking and motor is off. If drained by bailing water and moving the timer forward to rinse, tub will fill and agitate,...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 30, 2010 | Kenmore 22622 Top Load Washer
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Kenmore 90 Series only agitates on heavy-duty cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22622 Top Load Washer Logo
266 people viewed this question
Sal De
 Brian Main
Brian Main
