Question about Edirol UA-4FX External Sound System
Outgoing noise from USB port on my UA-4FX
That noise become to annoy me. I wonder if anybody has such trouble... Could
it be the usb cord guilty?
  • mikecartermu Nov 07, 2008
    I'm getting the same problem! and it's only recently, and not with my laptop, just my PC, i have no idea why, could it be a vista update or something? its like a high pitched whiney noise, and it seems to make it change volume when you move the USB cord?
  • 3 Answers
Probably not the USB cord because the chances of a faulty USB cord are slim, and I think it's the computer or the input/output chord.
Posted on Nov 08, 2008
Hi, my Edirol UA-4fx is having a problem. The Advanced Effects don't work at all. I get audio, but without any of the effects. Nothing lights up on the faceplate except for the blue usb light. I've tried...
Unplug, change the hardwae switch on the unit to "advanced driver" = "off" and reconnect. It seems that the onboard effects are not available when in advanced mode. :(
Dec 28, 2010 | Edirol UA-4FX External Sound System
LOT OF HISS I HEAR . HOW TO REDUCE IT ......
Since the edirol is USB powered try using it without any other USB devices connected. Maybe some USB disk or flash takes much power from the USB and the edirol works with less power. If in that case works fine, plug in the other USB devices on by one to find where is the problem. Always check the line input of the edirol, cause mic input makes too mauch amplification and the noise level is critical.
Stelios.
Feb 21, 2010 | Edirol UA-4FX External Sound System
Contents of box.No instructions.
when you connect the device to the pc it will detect new hardware and you will be ready to go.
you can download the driver for your OS here:
http://www.roland.com/products/en/_support/dld.cfm?ln=en&dsp=0&iCncd=1039
Jan 19, 2009 | Edirol UA-4FX External Sound System
UA-4FX Very static-like feedback / interference
its electromagnetic interference from power source of laptop. you can get an audio connection wire that reduces this
Sep 19, 2008 | Edirol UA-4FX External Sound System
Outging voice is off in Voipcheap
Sound card Xwave QS3000A 9903 + download
May 06, 2008 | Edirol UA-4FX External Sound System
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
No sound out from input
It's probably your computer, more specifically the type of application you're running it on/in. Also, when you install or fiddle with the settings, you have to be careful because it can be so confusing fixinfg them.
Dec 12, 2007 | Edirol UA-4FX External Sound System
Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Aug 29, 2006 | Edirol UA-4FX External Sound System
Problems with the internal efxs.
this is a usb bus powered, and maybe you got problem with the usb port, this happen many times the port can supply the correct voltage to the unit, do you have acces to other compu? try in it, if not then you are rigth, the ua-4fx is broke...good luck
Aug 10, 2006 | Edirol UA-4FX External Sound System
Timing and noise
That's usually caused by problems with the usb port on your computer. The best solution would be to buy an PCI USB CARD that you would use only for your UAFX4.
Aug 09, 2006 | Edirol UA-4FX External Sound System
Edirol UA-4FX External Sound System Logo
96 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
