Question about Dell 3010cn Laser Printer
Printing in grayscale
My printer is out of yellow toner. can I print in balck and white in the meantime? I have tried and keep getting message to replace yellow toner. Can I override this and print in balck and white until toner arrives in 3 days?
  • gnil Dec 21, 2008
    How do you override to print black and white? It just keep on flashing to replace the toner
    Problem Solver:
  • 8 Answers
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Posted on Oct 20, 2011
  • 113 Answers
Yes u can use it with black and white
Posted on Nov 01, 2008
I installed the latest driver, 61.82.61.41 and now whenever a user tries to print in grayscale, it prints black pages with white text
Kindly check the printer settings and preferences. Maybe it was set to grayscale, afterwards, try to do a print alignment and last resort is check toner if it's clean. Try to wipe with paper towel and do the printer test. Hope it may fix your problem :)
Jul 12, 2011 | HP LaserJet 3600n Printer
Using the Pixma mp800, running from windows 7, when I try to print in black and white photographs, the printer adds greens. How do I correct this?
your printer makes black from cyan, magenta and yellow when you tell it to prin black and white photographs. In the Printer Preferences you will find an option that is called: Print in High Resolution Grayscale using only the black cartridge.
If you check this function your printer will print only black and white with grayscale and will not use the color cartridge.
Jun 06, 2011 | Office Equipment & Supplies
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
My company has an HP laserjet 5500 printer. We ran out of yellow toner and did not order a spare. The machine keeps flashing 'out of/replace yellow toner'. We do not have the manual readily...
I do not believe you can get around the yellow toner, in the startup self diagnostic it checks all of the toners, and will not proceed if it has an error. Go to a big box store and either get your toner or a low end grayscale laser printer, sorry I could not be more helpful.
Jun 28, 2009 | HP Office Equipment & Supplies
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Disable color printing
For your HP 7310xi you have an icon by your clock. Right click on it once & a window will open click Launch/Show. Open printer settings. Another windows will open. Click on the color tab. Under Color Options click to pring in grayscale. The HP will print in balck & white untill you uncheck print in grayscale.
Feb 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printing in Grayscale or black
Too few manufacturers will allow their units to print in grayscale when a color toner is low or empty. The only way to get your unit working is by installing the required toner. By the way, start a budget to buy the transfer belt, drum unit, waste toner bottle and fuser unit. These are also consumables with a lifecycle.
Oct 01, 2007 | Samsung CLP-500 Laser Printer
Dell 3010cn Laser Printer Logo
197 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
