Question about Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350
I can't type in the address or state for directions
  • 3 more comments
  • lisageorn Nov 07, 2008
    I am having the same problem, WHERE TO? , ADDRESSES, and then I am unable to enter a state........after entering one letter to spell a state, it automaticalle says NO MATCHES FOUND. What is up with this.......hope someone can help................thanks
  • meredithalec Nov 26, 2008
    I have the exact same problem but can't figure out how to start it in maintenance mode like you said to do. How do I do that?
  • Anonymous Jan 08, 2009
    I have exact the same problem, and I did go into the maintenance mode and cleaned up everything, but it still doesn't work.
    Well, the map , City Navigator North America NT2009, is checked, but still. Is that possible the map expired so that I can't search for address anymore? If so, that sucks~
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    What caused this problem was that your map somehow got turned off. At the main menu, click the wrench symbol, then the map icon and then map info.
    Make sure the map is checked. If it's not, you will not be able to search for anything.
    Probably when you cleared the user data, the factory default boot-up re-enabled the map.
    - Jim
    SHARCNET-USA
I just want thank billm0066. I was having the same problem, But your solution worked great!
Thank You.
Posted on Jan 08, 2009
Thanks, this solved my problem.............thanks for taking the time to post this solution!!
Posted on Nov 19, 2008
When powering up your Nuvi 350, hold your finger on the lower left corner until it asks to start in maintenace mode. Click yes. Then click clear user data, and click clear waypoints. Also click view diagnostics to make sure there arent any problems there. Once thats done reboot and you should be good to go. Mine did this same exact thing. I almost bought a new one last night, but I did this and now it works like it did before.
Some of my symptoms:
Would not allow me to search for a state. As soon as I type one letter, it would say no matches found
When I click view map, nonce of the streets were there. Just highways, and it would be off a little bit
It still shows the time and mph
Boots up like normal
Garmin NUVI 350 only loaded Southeast States Want all 49 states
Try using a compatible SD card to have Garmin Express load all 49 states to the SD card. It is possible that you do not have enough free memory in your NUVI 350 for all 49 states.
Dec 31, 2016 | Garmin nuvi 350 GPS Receiver
Garmin 350 doesn't recognize any states
Try calling customer service 1-800-800-1020
They were able to help me by linking to my nuvi through my computer
Sep 18, 2009 | Garmin nuvi 350 GPS Receiver
Try to type in address and it says state not found or no matches
Your maps are either outdated or have become corrupted. Your best bet would be to update the unit. The new updates will correct your problem as well as give you the neat new item that allows the unit to actually tell you what street/road/freeway you are on. For example "Turn right on Division Street in one quarter mile off of Clinton" and it will also use a "ticker" at the top so a person can read the same directions. You should also check the other options as you can change your icon from a car to a boat to a semi to an eagle to a turkey(leg) to a herse to a jogger to even a snow shovel or a kid on an inner tube. You can add a 2GB SD card and increase the memory of your unit even more. Now the street recognition only works on units 260W and up and you can even change the voice to an elf or a ghoul and add in halloween-xmas-st patty's day and other holidays to your unit.
To do all of this you need to go to Garmin.com and locate the legacy updater on the webpage by typing in your unit and serial number on the bottom. Go here and have fun http://www8.garmin.com/support/download.jsp
May 08, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 350 won't accept addresses -
I called garmin and they walked me through the solution - select the NA map version under settings and restart.
Oct 02, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi--not working properly
download the map for your state and or region gaemin is the only gps that requies you to do this. tom tom is a better product and dosent require downloads
Aug 25, 2008 | Garmin nuvi 350 GPS Receiver
Canada
The Nuvi 350 comes with US, Canada and Puerto Rico. When you press Where To? and it asks State/Province, type a Canadian Province, such as Ontario. See what it asks next. It should ask for the City. Try Toronto. Then press Done twice. It should provide you with some addresses in Toronto. This should show it is mapping for Canada.
Jun 16, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
May 17, 2008 | Garmin nuvi 350 GPS Receiver
Cannot insert addresses!
Got it!! For those getting the "No Matches Found" headache. Here's the solution:1. Go to "Settings" 2. Go to "Map" 3. Go to "Map Info" 4. MAKE SURE that "City Navigator North America NT 2008" is CHECKED. It fixed the problem for me. Hopefully it will fix yours all the same. God Bless.
Apr 02, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
232 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
