Question about Compaq Presario 5000 PC Desktop
99 cadillac deville
Retained accy power items(radio,windows,wipers) stay on when ignition is turned off and door is opened. the stay on until the batt dies.
    Problem Solver:
  • 19 Answers
Replace the ignition switch.
Posted on Dec 16, 2008
06 Pontiac torrent radio continues to run when ignition is in off and key removed, even after drivers door opened, passenger door open then radio stops
Driver door switch ,ajar switch . This switch is a input to the BCM - body control module .
Retained Accessory Power Description and Operation
Retained accessory power (RAP) is a vehicle power mode that permits the operation of selected customer convenience items after the ignition switch is turned OFF. These selected items will remain in operation until a passenger compartment door or liftgate is opened or until the RAP function timer reaches its shut-off limit.
The class 2 RAP power mode is mapped to GMLAN serial data circuit as Off Awake power mode. Refer to Data Link Communications Description and Operation for more information on data link communications. The BCM monitors the ignition switch signals, battery condition and the doors status to determine whether RAP should be initiated. The modules that support the RAP power mode will operate the systems under their control as required by their RAP power mode strategy.
RAP will end when one of the following conditions is met:
• The BCM detects the opening of a passenger compartment door.
• The RAP timer expires.
• The battery capacity decreases below a prescribed limit.
• Any other ignition switch state is chosen.
The function supported in the RAP power mode is the operation of the radio.
It would go off on it's own in ten min.
Sep 16, 2017 | Pontiac Cars & Trucks
2006 chevy impala radio & dash lights stay on now when ahut car off, key out and close and lock doors automatically. Never happened before. Help please..
Could be relay contact's stuck closed allowing power to stay on . Or it could be a BCM - body control module problem .
Retained Accessory Power (RAP)
The retained accessory power (RAP) system allows certain vehicle functions to operate for a specific amount of time after the ignition switch is turned OFF. The body control module (BCM) monitors the ignition switch position, battery condition, and each door ajar switch status to determine whether RAP should be initiated or terminated. RAP is controlled with two different methods; serial data and relay control. Some modules receive a RAP message from the BCM over the serial data circuits. Serial data controlled RAP is deactivated as required by their modules RAP power mode operation. Other subsystems are activated directly by the BCM through a RAP relay. Components and systems that are active in RAP are also activated anytime the ignition is any position other than OFF regardless of the door switch signals.
Relay Controlled RAP
The BCM keeps the RAP relay energized during all power modes, except Off-Awake and Crank. The relay is also energized for approximately 10 minutes after shutting the ignition OFF and removing the key, providing no door is opened.
Relay controlled RAP will end when one of the following conditions is met:
• The BCM receives an input from any door ajar or open switch indicating the opening of any door after the ignition key is out of the ignition.
Important: If the BCM is receiving any door ajar or open signal from those switches when the ignition key is turned OFF, RAP will not initiate.
• The BCM internal timer for the RAP expires after approximately 10 minutes.
• The BCM detects a decrease in battery capacity below a prescribed limit.
Systems powered by the RAP relay during the RAP power mode are as follows:
• A/T shift lock control solenoid assembly (w/ floor shifter)
• Power window circuit breaker
• RAP fuse
• Inside rearview mirror (DD6)
• Sunroof (CF5)
Serial Data Controlled RAP
RAP systems controlled by serial data are as follows:
Radio
Radio RAP activation/termination is the same as relay operation with 1 exception; the only door switch that will turn off the radio during RAP is the driver door open switch.
Vehicle Communication Interface Module (VCIM) (Onstar®)
VCIM RAP activation/termination is the same as radio operation with 1 exception; if there is an active call when the ignition key is turned off the VCIM will remain in RAP mode, and keep the radio in RAP mode until the call is terminated.
Do you know what a DTC - diagnostic trouble code is ?
DTC B1475 00: Retained Accessory Power Circuit
Your best bet , take it to a Chevy dealer !
Jan 31, 2017 | 2006 Chevrolet Impala
The car is parked, turned off, and the doors locked. Came outside this morning and the radio was on with no key in the ignition. What would cause the radio to run without a key in the ignition?
The conveience delay module may have a problem if equipped. It is designed to operate some of the features with the ignition turned off( radio,wipers,power windows etc) until the driver opens the door and power is then cut to these features.
Jul 25, 2015 | 2002 Kia Sportage
Ignition switch in off position. I can remove key but all components are not off. Wipers will still come on and windows will still go down. Ignition switch??
What make model an year vehicle ? If you open the door do they still work ! Vehicles have Retained Accessory Power (RAP) this allows radio , windows an wipers to work for about 10 minuets after key off or until one the doors is open !
Apr 09, 2015 | Cars & Trucks
Where Is radio fuse located in 2002 avalanche
if you look in the owners manual it will have a listing of the fuses and the location of the fuse box. 6-64
"The fuse block access door
is on the driver's side edge
of the instrument panel.
Pull off the cover to access
the fuse block."
NAME Usage
L BODY Retained Accessory Power Relay
LOCK Power Door Locks
DRV UNLOCK Power Door Lock Relay
HVAC 1 Climate Control System
CRUISE Cruise Control, Instrument Cluster
IGN 3 Ignition, Power Seats
4WD Four-Wheel Drive System,
Auxiliary Battery
CRANK Starting System
INT PRK Interior Lamps
L DOOR Power Door Lock Relay
BRAKE Anti-Lock Brake System
RR WIPER Not Used
ILLUM Interior Lamps, Cargo Lamps
SEAT Power Seat Circuit Breaker
TURN Exterior Lamps, Turn Signals,
Hazard Lamps
UNLOCK Power Door Locks
HTR A/C Climate Control System
WS WPR Windshield Wipers
IGN 1 Ignition, Instrument Panel
AIR BAG Air Bag
MIR/LOCK Power Mirrors, Power Door Locks
DR LOCK Power Door Locks
PWR WDO Power Window Circuit Breaker
IGN 0 PRND321 Display, Odometer,
VCM/PCM
SEO IGN Special Equipment Option, Ignition
SEO ACCY Special Equipment Option Accessory
RAP #1 Retained Accessory Power Relay
RDO 1 Audio System
RAP #2 Rear Power Windows,
Sunroof, Radio
if you do not have a owners manual here is a link\
http://www.chevyavalanchefanclub.com/resources/2002_owners_manual.pdf
Sep 30, 2012 | Cars & Trucks
1993 cadillac deville no lights on eletronic fuel data or eletronic climate control ,blower motor not working, i tested blower its good ,i tested #7,20 amp fuse ,good .no power to #4,10 amp fuse to b
Fuses 6-7-8-9 are powered from the ignition key switch.
Fuse 4 is powered from the RAP relay number 2 in the relay box.
RAP is for retained accessory power - its the relay that keeps power going to the radio and things after you turn the key off and before you open the door.
Jul 29, 2012 | 1993 Cadillac DeVille
99 cadillac deville delegance...im lost with this?! Ok, after ive turned off the radio, killed the engine, andgot out it sounds as if the speakers are still on?? My battary died the other day so the next...
What you may be hearing is hum from a low voltage power module under the dash, which is activated every time you open a door. It should shut off after doors are closed, all timed devices (such as cabin lights) turn off and the key is not in the ignition. If your battery is in good condition, then either this module, the keep-alive module or something else drawing current is not shutting off the way it is supposed to. Start by checking for trouble codes (DTCs) with a good code reader.
Jan 20, 2018 | 1999 Cadillac DeVille
I need to adjust the wiper arm on a 1997 suburban, it hits the side of the window.
Wiper Arm & Blade (Front) Removal & Installation Wiper Blade To Remove:
  1. Turn ignition switch to ACCY position.
  2. Turn wiper switch to PULSE position and turn ignition OFF when wipers are stopped in the innerwipe position.
  3. Push the wiper blade clip button IN and remove wiper blade from wiper arm.
To Install:
  1. Insert wiper arm hook through opening in wiper blade.
  2. Place wiper blade pivot in the inside radius of wiper arm hook.
  3. Pull on wiper blade pivot into hook until it locks into place.
  4. Check wipers for proper operation.
Wiper Arm To Remove:
NOTE: Mark position of wiper blade on windshield to ensure proper position upon reassembly.
  1. Remove washer hose.
  2. Lift wiper arm from windshield and use a screwdriver to disengage retaining latch.
  3. Remove wiper arm from shaft.
To Install:
  1. Place wiper arm on shaft so that wiper arm aligns with marks placed on windshield.
  2. Press arm assembly on shaft and push retaining latch IN.
  3. Connect washer hose.
  4. Remove windshield markings and check wipers for proper operation.
Oct 26, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Hi! I have a 2002 Cadillac Deville and yesterday I unlock the door with key pad and opened it and when I did I heard the chiming sound that it makes when you have the keys in the ignition with the door...
It may be trying to get your attention for an open door, trunk lid or other item requiring attention. Check your owner's manual for items that can cause it to chime.
Aug 03, 2009 | 2002 Cadillac Deville
Compaq Presario 5000 PC Desktop Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
