Question about Dacor Preference PGR30 Gas Kitchen Range
DACOR PGR 30 Error code 1
The gas oven/stove displays a F-1 error intermittently and it starts beeping, when I turn the circuit breaker off it resets and it happens again anywhere from 1-24 hours. The problem occurs without using the unit.  I have already replaced the circuit breaker and the same issue persists.
Thanks.   Jake
  • 1 more comment
  • jakeddoc Nov 07, 2008
    I unplugged it for 30minutes and plugged it back on the same problem occurs within minutes
    Any suggestions as to where to purchase a control board?---
  • jakeddoc Nov 18, 2008
    Unfortunately tried to enter the model number/ and or serial number to the oven and I got no answers the site you suggested.
    PGR30S/LP
    KB0090141
    Above is the model number and serial number....
    Genius:
  • 1,239 Answers
Hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Posted on Nov 07, 2008
  • ABHISHEK.C
    ABHISHEK.C Nov 07, 2008
    if problem with control panel
    When the oven setting control malfunctions, the oven won't heat. Here's how to repair an oven setting control:
    Step 1: Remove the control knob
    Step 2: Remove the back service panel or the front panel, if necessary. Remove other control knobs as needed to remove the panel. The oven setting control is located directly in back of the control knob and is usually held to the control panel by two screws.
    Step 3: Testing the control with a volt-ohm-milliammeter (VOM) is not recommended, because the results will not always be conclusive. If you suspect that the setting control is faulty, the best procedure is to substitute a control that you know is working, or you could simply replace the faulty control with a new one made for the oven.
    Step 4: Disconnect the electrical lead wires from the control terminal and lift out the control. Connect the new control the same way the old one was connected.
    Scholar:
  • 44 Answers
Hello jakeddoc
Welcome,
You said, your get a recurring F1 beep even after I press "reset" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it tomorrow!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
    Genius:
  • 2,035 Answers
F1 error means Element relay circuit failure: Control board may be bad needs replacements.....
Good luck....
Posted on Nov 01, 2008
  • Anand Kumar
    Anand Kumar Nov 07, 2008
    Please click here and check for the part....
  • Dacor Master
  • 19,396 Answers
Try first unplugging power cord for ten minutes, and see if this clears the error message.
  • Ginko
    Ginko Nov 07, 2008
    F1 means Element Relay Board error.
    If the oven is not heating, that means that the Element Relay Board is faulty, the element is not powered and the oven won't bake.
    You can find replacements and diagrams to locate the board here. Just click and insert the exact model number.
    If the oven is heating normally, then it is a logic error on the main control assembly, stuck with Element Relay Board error, that otherwise is powering the oven regularly.
    Sometimes in this case you replace the Element Relay Board and the error stays there. See here :Dacor Oven F1 Error
    If you need to call a technician, or to get parts, you can also use the phone number listed on the owner manual to get in touch with Dacor.
Dacor RSD30S F1 Error Code
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Dacor PGR 30 oven does not heat
I have had the same miserable experience - replacing the brain, touchpad, expensive parts - for this supposedly high-end appliance.
Have you checked the ignitor bar? See a good explanation of that at http://www.ignitors.com/oven-ignitors/
and also http://www.theignitorstore.com/product/frigidaire_oven_range_igniter_5303935066/range_oven_igniters
Nov 23, 2009 | Dacor Preference PGR30 Gas Kitchen Range
My Dacor PGR-30 oven won't heat. It stays on 135 degrees. There are no codes set.
Called Dacor with same problem. They said the high temp switch needed to be reset but wouldn't tell me how to do it.
Looked at another site and found out how. On double oven remove grill that latch sticks out of. There should be 6 screws. On left side is a switch with a red button that faces inward. Press this button until it clicks. Test oven by turning on to see if this fixes problem. It did for me.
Rescrew grill back on being careful that the latch continues to line up with the door.
Nov 12, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Preference PGR30 Gas Kitchen Range Logo
457 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
