Question about GE Microwave Ovens
El microwave esta bloqueado con f3 - GE Microwave Ovens
  • GE Master
  • 9,098 Answers
Usted tiene un cortocircuito teclado. Esto puede ser muy peligroso y resultar en un incendio.
Por lo tanto, hasta que sea reparado, por favor, deje desenchufado o dejar la puerta abierta cuando; s no está en uso, y por favor no la deje desatendida en ejecución.
( usa le por favor: http://translate.google.com/translate_t# )
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
You have a shorting keypad. This can be very dangerous and result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it;s not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 09, 2008
El plato gira y la luz se enciende solo cuando se abre la puerta con la puerta cerrada el tiempo descuenta pero no calienta
Apparently there is something wrong with the door interlock or possibly the control board.
Mar 30, 2014 | GE Microwave Ovens
COMO REPARO UN MICROONDA PANASONIC CON ERROR H98
H97, H98 o H99 significa que hay un problema con el inversor, magnetr?n, o el circuito de programaci?n digital.
Debido a las tensiones letales utilizados y producidos, no se recomienda que una persona sin experiencia de trabajo en estos. Yo recomendar?a que se ponga en contacto m?s cercano de servicio autorizado de Panasonic.
Soluci?n de problemas de circuito inversor (U) y Magnetron
Este horno est? programado con un sistema de auto diagn?stico c?digo de error que le ayudar? a solucionar problemas, H97, H98 y H99 son el fracaso y el inversor siempre magnetr?n ?reas problema en el circuito. Esta secci?n explica los c?digos de falla de H97, H98 y H99. H97, H98 y H99 aparece en la ventana de visualizaci?n poco tiempo despu?s de clave de arranque es presionado y no hay oscilaci?n microondas.
Forma alternativa para solucionar el horno con aire acondicionado Ampere medidor utilizado.
H97, H98 y H99 aparece en la ventana de visualizaci?n un corto tiempo cambiar clave de inicio es presionada y no oscilaci?n de microondas con amper?metro de CA utiliza para solucionar problemas.
Compruebe filamento del magnetr?n abiertos o en cortocircuito a la carcasa antes de proceder a determinar un buen magnetr?n.
Espero que esta informacion le sea de ayuda (recuerde valorar esta respuestas gratuita).
Sep 20, 2011 | Microwave Ovens
Buenos dias deseo conocer el manual de mr coffee model ecm10 gracias
Visite este enlace para la descarga del documento en formato PDF: ECM10_espresso.
Suerte y exitos!!! (recuerde calificar y comentar esta respuesta).
Apr 14, 2011 | Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
Aonde encontro membrana
En Welbilt MR95TW, el número de parte de "keypad" es MW-7450-03.
?Puede no estar disponible? No se seguro.
Tritronics del intento aquí.
Buena Suerte.
Estamos feliz de ayudarle con consejo libre y apreciamos su grado pensativo de nuestra respuesta.
Aug 11, 2008 | Welbilt MR95TW Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
No est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
Jan 24, 2008 | Panasonic NN-S768BA/WA Microwave Oven
MW8108P 1100 Watts Microwave Oven
Aqu? est? la conexi?n al manual para su horno; http://www.servicemanuals.net/freemanuals/MW8104SSIB.pdf Puedo s?lo lo encuentra en ingl?s, si usted desea traducirlo entonces el mejor sitio es; http://www.freetranslation.com/ Aqu? est? la conexi?n para el sitio de emerson si usted desea contactarlos; http://www.emersonradio.com/main.html No utilice su horno con una puerta da?ada. Potencialmente le herir? o su familia, da?ar? posiblemente otros art?culos el?ctricos o empezar? un fuego, y emitir? quiz?s una se?al ilegal de la radio que puede intervenir con otras transmisiones. Obt?ngale repar? o reemplaz?. Espero que esto ayude:) Here is the link to the manual for your oven; http://www.servicemanuals.net/freemanuals/MW8104SSIB.pdf I could only find it in english, if you wish to translate it then the best site is; http://www.freetranslation.com/ Here is the link for the emerson site if you wish to contact them; http://www.emersonradio.com/main.html Do not use your oven with a damaged door. It will potentially injure you or your family, possibly damage other electrical items or start a fire, and perhaps emit an illegal radio signal that may interfere with other transmissions. Get it repaired or replaced. I hope this helps :)
Apr 19, 2007 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
