Question about GE JVM1490 Convection/Microwave Oven
GE JVM1490 Microwave Troubleshooting
Electech-
You responded to my post on the JVM1490. When you say 40V on the secondary are you talking about the LV transformer or the HV transformer?
  • 905 Answers
Sorry i didn't know you came here but I left a link for the best of tests for your microwave
but here it is again http://repairfaq.ece.drexel.edu/sam/micfaq.htm#mictsthvd
please be very careful if you have to check the hv transforformer , but these test will help you find the problem , if you get stuck i'll be checking this thread for a few more hours , otherwise we will have to continue tomorrow
electech
Posted on Nov 01, 2008
  • jason Nov 01, 2008
    i also wanted to add if the magnetron was bad the micro would still power and your display would work also.
    and working with the high voltage on that micro will require a special probe to check that hv tx or there is one other way without power
    If the main fuse is upstream of the controller, then any short circuit in the microwave generator will also disable the controller and display. If this is the case, then putting in a new fuse will enable the touchpad/display to function but may blow again as soon as a cook cycle is initiated if there is an actual fault in the microwave circuits. Therefore, try a new fuse. If this blows immediately, there may be a short very near the line cord, in the controller, or a defective triac (if your oven uses a triac). Or, even a shorted oven lamp - remove and inspect the light bulb and socket. If it does not blow, initiate a cook cycle (with a cup of water inside). If the oven now works, the fuse may simply have been tired of living. This is common If the fuse still blows immediately, confirm that the controller is operational by unplugging the microwave generator, power relay, and/or triac from the controller. If a new fuse does not now blow when a cook cycle is initiated - and it appears to operate normally - then one of the components in the microwave generator is defective (shorted). See the section: Microwave generator problems.
    Some models have a thermal fuse as well and this may have failed for no reason or a cooling fan may not be working and the oven overheated (in which case it probably would have died while you were cooking something for an important guest - assuming you would use a microwave oven for such a thing!).
    Other possible causes: bad controller power supply or bad controller chip.
    Let me know what you get from these tests
    Electech
JVM1490 owners manual
GE has the manuals for their products on their support site: http://www.geappliances.com/service_and_support/literature/ . The direct link to the Use and Care manual for most JVM1490 Spacemaker Convection/Microwaves is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40345.pdf .
I hope this helps.
(note: you will need Adobe Reader or a similar product to read the manual.)
Dec 02, 2011 | GE SpaceMaker Microwave Ovens
FAILURE TO TURN ON. Outlet power is ok.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE JVM1490 Convection/Microwave Oven
Microwave acts like its working but doesn't heat. The convection oven works.
Most likely causes are a blown fuse in HV area of microwave or an open thermal protector or thermal fuse.
Less likely causes are failure of various parts in the HV area.
Due to the lethal dangers inherent in microwaves, servicing of these parts is likely best left to a professional. That said, if you are technically versed I can point you in the direction of some good resources for troubleshooting and repair.
Oct 21, 2010 | GE JVM1490 Convection/Microwave Oven
Convetion heat not working
sounds like the magnetron is gone ...they usually have a 5 year part warranty
Jul 02, 2009 | GE JVM1490 Convection/Microwave Oven
Microwave oven
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 18, 2009 | GE JVM1490 Convection/Microwave Oven
Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Dec 26, 2008 | GE JVM1490 Convection/Microwave Oven
Thanks! I did see that info about the totally dead unit. That's a great troubleshooting guide!
I'm calling it a day for today.
Thanks again!
Nov 01, 2008 | GE JVM1440 Microwave Oven
JVM1490 Low fan noise when not in use shuts off when door is open turns back on when door is closed?
it sounds as if your door switch is out of line. If this only happens when you close the door you may want to check they switches on the inside. one of them is either bad or you just may need to line it back up.
Jul 08, 2007 | GE JVM1490 Convection/Microwave Oven
JVM1490 IS BEEPING EVERY 4-5 MIN ONE BEEP
The manual states that it will beep once a minute after food cooks until you open the door or press stop. Other than that, it sounds like an error condition. But you might contact the GE Answer Center at 1-800-626-2005 Monday 6 a.m. ET through Saturday midnight ET. The owner's manual is available here: http://www.geappliances.com/service_and_support/literature/
Mar 15, 2007 | GE JVM1490 Convection/Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
233 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
