Question about Kenmore 62622 Microwave Oven
Where is the capacitor located in the Kenmore Elite?
My husband needs to locate the capacitor in order to discharge it. . . where is it located?
Thank you
  • Kenmore Master
  • 9,086 Answers
It depends on the model. It's usually behind the grille or control panel.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Nov 08, 2008
Kenmore elite microwave model no. 721.66339011 just stopped heating ...anyone know what or how to fix?
Hello, the fuse normally is located behind the control panel and easily accessed by removing the panel. Here is a schematic to assist you in locating the part...
Dec 17, 2016 | Kenmore Microwave Ovens
HP capacitor location
The capacitor is located to the right, remove top cover, follow the leads from the keypad to the circuit board, capacitor may be hidden under a flap of plastic, "silver in color and rectangular in shape, and a few inches long. Don't forget to unplug and discharge capacitor, "lethal voltages"
Mar 05, 2012 | GE Microwave Ovens
Where is the fuse in my Kenmore Over the stove Microwave oven
The fuse is located under the keypad in towards the high voltage capacitor "silver rectangular in shape" before you take it apart "unplug and discharge capacitor" there are dangerous high voltages present, the fuse is a ceramic type and must be replaced with the identical size and rating. Now if the fuse blows again it is more than likely one of the door switches is defective.
Feb 09, 2011 | Kenmore 62702 Microwave Oven
Light is burnt out. How do I replace the bulb for an EM-S260
Befor you do anything you need to read up on how to discharge a high voltage capacitor so that you avoid all sort of injury as well as death. Once you have read up on how to discharge the high voltage capacitor, you simply remove thecasing of the microwave, discharge the high voltage capacitor, once that is done, you are safe to locate and replace the bulb, To obtain a bulb contact your closest Sanyo authorised repair agent, they should either have one in stock or they will be able to order one for you.. Good Luck.
Dec 02, 2009 | Sanyo Microwave Ovens
Locating capacitor and diode to discharge capacitor
Alot of the Panasonic models had the Transformer and Capacitor and Diode built into the power board situated bottom right as you look at the appliance.
Dont know of a way to actually discharge this arrangement.
Apr 07, 2009 | Panasonic NN-S753 Microwave Oven
Microwave will not heat anything.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Feb 28, 2009 | Kenmore 63672 Convection/Microwave Oven
Microwave locked
Jan 23, 2009 | GE XL1800 1100 Watts Microwave Oven
My microwave Kenmore model 665.60601000 2001make a strange noise
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Jan 17, 2009 | Kenmore 63792 Microwave Oven
Microwave heating
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Dec 17, 2008 | Kenmore 63792 Microwave Oven
Kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
Oct 25, 2008 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
126 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
