Question about Philips 32PT9100D 32" TV
Power I recently purchased a philips hdtv-ready lcd tv model 37PF7321, which was delivered 4 days ago. But today when I tried to turn on the tv, it doesn't want to turn on. The standby mode light just keeps blinking red. What should I do?
    President:
  • 3,130 Answers
Call back the store and tell them to bring you another one. If you paid by credit card tell them you are going to dispute the bill if they dont come out and pick up this TV and bring you a new one.
Posted on Sep 20, 2006
My phillips lcd 46 The GREEN light blinks on it come on black screen the it goes off again and does some thing over and over just got this tv new three days ago model 46PFL5705D
This tv is having a power supply board issues,that the electronic board where the tv power a/c cord plug into it.This is a new tv.Return the tv where u bought it quickly and get a new tv replacement.
May 08, 2011 | Philips 42PFL5603D - 42 IN. LCD HDTV
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips 37 lcd tv will not turn on no sound no pic light goes green then blinks 6 timmes pause 6 times pause etc any ideas
Right now the TV is in " Protection Mode " and the blinking light should be a trouble code.
Try leaving the TV unpluggeds for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 06, 2009 | Philips 37PF7321 37 in. LCD Television
Tv shuts off, red status indicator lamp flashes.
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 32PT9100D 32" TV Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
