Sink adapters for washing machine
I was looking for an adapter for the washing machine to the sink that can use hot and cold water in one adapter.
  • victor_tenti Nov 03, 2008
    Thank you for helping out.
    Victor
  • 566 Answers
Hi from uk there is an adaptor for this pupose it is known as a YPIECE which has the facility to have two pipes to connect to one cold fill machine not expensive it may also be called a collector breaching in your location?
Posted on Nov 01, 2008
Can i use my hotpoint first edition washing machine with just a cold water feed under sink it has a hot and cold feed but i only have a cold water feed under sink
you can of course but set the temp control to cold only . normal is not from under any sinks tho . have a plumber come and add a hot water outlet for you
Apr 28, 2015 | Hotpoint Washing Machines
I've had my machine for at 7 years now, does it have to have both the water hoses connected, my seems to need both, and I hate using hot water for washing, is there any way to stop the need for the hot...
Some washers require that both water sources are connected. If you are content with cold - water washing only, I would get a Y-hose connector and run both sides of the washer to the cold water line. See picture below for details.
Mar 03, 2015 | Washing Machines
Can we operate our WFS1273BD washing machine on cold water only? We are on instant gas hot water and have gone through a 45kg bottle in 3 weeks. We have lived in this house before and the washer is the...
ABSOLUTELY! Purchase a 'Y' adapter from your local hardware store and attach the hot and cold lines on the washer to the 'Y' attached to the cold faucet. You won't be able to wash in warm or hot without changing the hoses, though.
Aug 17, 2011 | Washing Machines
When connecting the machine to the taps, do you need to connect the machine to hot from the geyser or the washing machine makes the water to be hot
I think you will find that all washers are able to heat water. If they are hot and cold fill, they use the heater if the hot water supplied is not hot enough for the particular wash. If they are cold fill only then they need the heater for all non-cold washes.
If you purchase the washer you are thinking of and it is cold fill only, it will have only one inlet hose, the cold water one and it is a straight forward installation- hose from washer screw into cold supply tap.
If it is hot and cold fill you have a choice- either go to the expense of plumbing hot water to it OR purchase a 'Y' 'tap' adapter. The adapter screws onto the cold supply (by the 'bottom' of the Y) and the hot and cold hoses which go to the washer are screwed into the (top) 2 ends of the 'Y'. The washer opens its hot valve, gets the only water supply which is cold through what it thinks is the hot hose and heats it up accordingly. When it wants cold it opens its cold valve and gets the cold water through what it thinks is its cold hose- which it is!
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 17, 2011 | Washing Machines
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
I am about to buy this model machine but before i do i need to know-does this machine heat up the water itself? or do i have to have a supply of hot water going into the machine in order for it to be hot...
John C
Apr 18, 2011 | Washing Machines
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Pulsating water in the hot water cycle
id be curious as to the age of this machine, because the newer models have what teh call adaptive water temp sensors that will optimize the water temp automatically.. your hot water may be "too hot" and your cold can be "too cold" and the valve corrects to a preset temp. this sounds like whats happening
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Does this machine need hot water or cold - Tricity Bendix aw 1200
Hello , I can help , if there is only 1 water inlet hookup it will be cold and some new machines heat the water on there own , if there are 2 water inlets it would be best to connect hot and cold to unit , if you do not have a hot water line available it should still be ok to put a Y adapter on your cold water line to both connections on your unit. Let me know how it goes. Phil
Dec 31, 2008 | Tricity Bendix AW1200 Front Load Washer
Washing Machines Logo
384 people viewed this question
Top Washing Machines Experts
