Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Limit switch not rotating when garage door moving up
I have a Sears garage door opener, bought in 1999 For some reason when the door is moving up the limit switch is not rotating and moving to the top sensor. The gears realy don't look used too much but there is a definite gap. Should I just replace the lmit switch and both plastic gears?
  • wk12 Nov 01, 2008
    Oops further inspection shows the top bearing plate is so worn that shaft was severely tilted causing a gap between the helical gear and the limit switch. Looks like I need to purchase the hole Gear Sprocket assembly.
  • 504 Answers
CHECK TO SEE IF THE UNIT CAN BE CLICKED IN PLACE TIGHTER.
IS THE LIMIT SWITCH BEING DRIVEN BY THE GEAR ON THE DRIVE SHAFT??
IF THE DRIVE SHAFT IS TUNING THE LIMIT ASSY AND IT IS PROPERLY IN PLACE REPLACE THE LIMIT ASSY.
Posted on May 29, 2010
Chamberlin garage door opens to top limit bounces back to return down about 6 inches and then returns to open limit. What adjustments are neccessary?
The limit switch of both the sides are not reached. The drive must be realigned to work till the door closes fully so as to touch the limit swittch to switch off.
Similarily the open door must go to the extreme point to cut off with the activation of the limit switch.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Belt drive sears opener, new, will only open halfway, why?
Depending on model there are 2 two controls for up/ down travel of the opener. This is known as the limit switch. When the opener runs a gear moves 1 switch at time and when the switch closes the motor shuts off.There are arrows next to each control which will tell you which way to turn knob to increase the travel.if already maxed out will will need to remove cover and look at the switches. You can remove the tiny gear clip, take off the gear and manually move it in to the position you need. good luck
Jul 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Installed garage door opener and the door opens then closes on its on
The down limit switch could be set to low. Try moving the screw clockwise to raise the stop point.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster bounces back up sometimes...
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can remove the cover and watch the limit switch assembly and get a good idea how it works.
Sep 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
check the end shaft platic cap is installed and runs freely between the rpm sensors.. that might be ur problem..
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Maybe motor
how old. what model. if old, gears may be stripped. take off cover and watch limit switches. are they moving; contacts ok ; wires connected.
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO, Model 139.53600. moves 4inches up/ down
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener problem
If the safety eyes are not connected you need to ho;d the button down until it reaches the close linit.
Feb 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
131 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
