Question about NetGear DG834G Router
HOW DO I ENABLE THE ROUTER
MY LAPTOPWILL NOT GO ON LINE WIRELESS.
Reboot router ,ensure the encryption key is the same at both ends of the wifi link.ensure that remote device is wireless enabled.ensure that devices are close renough for a good signal,experiment with positions.
Posted on Nov 06, 2008
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
Wifi is turned off. How do I turn it on?
Stuart,
Some NetGear routers have a wireless button to enable/disable the wireless feature. Look for a wireless LED on the front of the router, if it is off check the back of the router for a wireless button. Press the button for 5 seconds to turn the wireless feature on/off. If that doesn't work you may need to login to the router to enable the wireless feature. Here's a snipet from the NetGear knowledgebase:
1. Type http://192.168.0.1 or http://192.168.1.1 in an Internet browser - some routers use the first URL while others use the second. If one of these does not bring you to the router's login screen, see If You Cannot Log on to Your Router.
2. Enter the user name and password; the defaults are admin and password unless you have changed them. NETGEAR strongly recommends changing the default user name for your network security.
3. Check Wireless Settings > Advanced > Enable Wireless Router Radio. For newer routers with a Genie interface, click on the ADVANCED tab > Advanced Setup > Wireless Settings > Enable Wireless Router Radio.
Note: You will need to uncheck two separate Enable Wireless Router Radio box if your router is dual band. One for the 2.4GHz and one for the 5GHz network.
I hope this helps.
Mar 15, 2014 | NetGear N150 / RANGEMAX 150 Router
WLAN line is not working
if w-lan light is not glowing on it, the wireless option is either disabled or the wireless capability is having problems with the router.
you can re-enable the wireless capability, by accessing the GUI page of the router. if you want more clarifications of information on it, please reply to this post. we can get it done
Mar 30, 2012 | Computers & Internet
My Belkin Wireless router has always only one or no bars of connection and my internet is always running slow or cant connect. The router is in the next room near the phone line with one single brick wall...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 22, 2010 | Belkin (F5D9230-4) Wireless Router...
How do I enable wireless on a 2wire 1800HG router?
Hook to any port by copper line and then from a browser access 192.168.1.1. If you received this WAP from Bellsouth/AT&T etc. you may need to get the admin password and user from them. There you will have a section for your wireless settings that is very similar to Linksys, Dlink, or any other wireless DSL router.
Mar 02, 2010 | 2wire 1800HG Router (RG1800HG00)
I am unable to enable wireless networking - the
So your on the GUI page of your router? you need to create the network name and password using your router connections. Make sure you have wireless adapter for you to be able to connect your computer wirelessly. If your having a problem to configure the wirless set up using your router contact your ISP.
Feb 21, 2010 | D-Link Xtreme N DIR-655 Wireless Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Wrt54g network map set
The only way to reinstall the router is to hard reset it by pressing the reset button at the back of the router for about 20 seconds then do a power cycle. Unplug the power to the router and the modem for 30 seconds. Power on the modem first and wait for the lights to go steady, then power on the router.
The only way check if there are other users accessing the router is via the router's Admin Interface, under Status tab, Local Network subtab and click on DHCP Clients Table.
To make sure that nobody is accessing the router without permission, enable wireless security. On the admin interface of the router, go to Wireless tab then click on Wireless Security sub tab. Enable WPA-Personal on the security mode then save the settings
Apr 26, 2009 | Linksys Wireless-G WRT54G Router
I have did the steps and i still can't get on line
This is a wireless "N" Router. that means it requires a "n" version adaptor in your computer too.
I assume you cannot connect at all at this point.
Unless you have the latest in PC's your not likley to have the N version installed. Unless you got the card as well at time of purchase.
Thats OK though as this router can also handle the other types of wireless connections too. You need to go to the router setup software and enable the B and G versions of wireless and you should see the router then. Disable the N features and see what happens.
Dec 24, 2008 | D-Link DIR-625 (790069292637) Wireless...
I connected my netgear wirekess router succesfull however after i installed the wirless dongle it comes up saying i am connected with a limited service and wont alloy me to go on line please help if u can
repair the connection by right clicking the wireless connection and choosing Repair. if that doesn't work then you should try to disable and then re-enable the connection. try adding the IP address of router to you list of DNS servers for the wireless connection.
Jun 23, 2008 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834G Router Logo
47 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
