Question about Rockford Fosgate Punch 800a2 Car Audio Amplifier
No sound output from amp.
There is no sound output from my 800a2 regardless of input level from the source unit. The amp is getting all the proper voltage, remote lead, ground, source signal, etc. the power led comes on, and the amp itself is drawing 15 amp's at idle. (increasing input voltage does not change the amp's current draw.) I checked all the switches, gains, etc. I took the amp apart and inspected everything visually, everything looks like new, no burnt smell. I am pretty handy with a soldering gun and a v.o.m. Do you have any ideas or suggestions for me to try?...THANKS..
    Scholar:
  • 148 Answers
It has bad parts. It should NOT be drawing 15amps at idle!! You need to grab a DMM and check the mosfets!!
Posted on Nov 02, 2006
Is there any way I can output the sound from the set to an amplifier & speakers
You need both an output from whatever it is you want sound from, as well as an input to your amplifier.
The source could have "audio out" sockets, or possibly a "headphone" socket.
The amplifier may have an "aux" input, or another input for something else that is not in use. You could edit your question and name the inputs on the amp. and outputs on your source to aid in getting advice, possibly also identifying what type of sockets are fitted.
The "audio out" would be a "line level" output, but the "headphone" output is likely fairly low level. It could still be high enough to drive into an "aux" input, worth a try.
You need suitable cables with end plugs to suit each end of the connection.
Apr 21, 2016 | Audio Players & Recorders
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
May 02, 2011 | AudioSource System 230 / 235 System
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
Cant get no sound
Try a different input source. I have had this happen before and the easiest way to diagnose the root of the problem was to take a home CD player out to my car and use the outputs to power the amp. If the amp works, move upstream to the RCA wires (unplug them from the back of your head unit and plug them into the home CD player). If that works, you know the stereo isn't putting out a signal. Good luck!!
Jan 26, 2010 | Alpine MRD-M501 Car Audio Amplifier
I have a Boss OL5KD Class D Monoblock Amplifier and I set it up but is no sound coming up from the speakers, can anyone tell me how to higher the volumen? where is located the volumen??I need to higher the...
Hello maydude01,
The Boss OL5KD does not have a volume control. It has an "Input Level" adjustment which is used to match the output from your head unit preamp output to the amp. It is the first rotary control just to the right of the input jacks.
If you have no sound at all, I'd suspect that something is incorrectly connected or there is no input to the amp. First make sure that the amp power light (green LED) is coming on when you turn on the receiver and that the protection light (red LED) stays off. Then check all of your wiring, especially the RCA output cables.
Initially set the controls like this: MASTER/SLAVE switch in MASTER position (left). INPUT SENSITIVITY 2v-8v (right). INPUT LEVEL, SUBSONIC FILTER, BASS BOOST, and LOW PASS FILTER; midrange. PHASE SHIFT "0" (left). Leave the remote level control disconnected.
After you've checked all wiring and initially set the switches and controls, turn the receiver on to about 3/4 volume. Now adjust the INPUT LEVEL to the left just until you begin to hear distortion, then turn it back right just a little. Adjust the other controls for best sound. Plug in the remote level control and make sure that it adjusts the bass up and down. You're finished!
If there's still no output from the unit after checking all of the wiring, either the unit is defective, it's not getting an input from the receiver, or the sub(s) are defective.
Hope this helps.
Aug 14, 2009 | Boss Car Audio & Video
What to do
Hello dodgeram1980,
If you are not getting sound from any of the 4 channels, I'd suspect that either the amp is not getting an input signal or the amp itself is faulty.
Here's the "no sound" troubleshooting step-by-step procedure from the JL manual:
1) Check the input signal using an AC voltmeter to measure the
voltage from the source unit while an appropriate test tone is
played through the source unit (disconnect the input cables
from the amplifier prior to this test). The frequency used should be in the range that is to be amplified by the amplifier (example; 50 Hz for a sub bass application or 1 kHz for a full range / high-pass application). A steady, sufficient voltage (between 200mV and 5.O-volts) should be present at the output of the signal cables.
2) Check the output of the amplifier. Using the procedure explained
in the previous check item (after plugging the input cables back into the amplifier) test for output at the speaker outputs of the amplifier. Unless you enjoy test tones at high levels, it is a good idea to remove the Speaker Connector Plugs from the amplifier while doing this. Turn the volume up approximately half way. 5V or more should be measured at the speaker outputs. This output level can vary greatly between amplifiers but it should not be in the millivolt range with the source unit at half volume. If you are reading
sufficient voltage, check your speaker connections as explained below.
3) Check to ensure that the speaker wires are making a good
connection with the metal inside the Speaker Connector Plugs. The speaker wire connectors are designed to accept up to 12 AWG wire. Make sure to strip the wire to allow for a sufficient connection with the metal inside each terminal.
Hope this helps.
Apr 30, 2009 | Jl Audio HD600/4 Car Amp
I got 4 ''15 inch kickers 2 5500watt power acoustik mono amps my problem is 2 kickers on the right side hittin hard but the 2 on the left not.i thought the amp on the left was bad so i took the rca of the...
Hello herb31,
It sounds like there is a difference in the signal levels on the inputs to the amps. You did not specify what the RCA's are connected to on the head unit side. If they are connected to a stereo pair of preamp outputs, you may be able to solve the problem by using only the channel with the higher signal and use an RCA "Y" adapter to split it to both amps. If they are connected to a dedicated subwoofer output on the head unit, make sure that the head unit is set for "subwoofer". Some less expensive head units, I know JVC in particular, has only 1 set of line outputs and requires you to go into their "PSM" (Preferred Setting Mode) to set the line output mode and if you select "subwoofer", then allows you to select the low pass frequency.
If you are converting speaker-level outputs through a "line out converter", check both the input and output levels.
Also, if you are splitting an output from the head unit, you still need to connect 2 RCA's to the amp inputs. The signal will be properly split if you use a 1-female to 2-male "Y" adapter. To feed the same signal to both amps, you would need 3 "Y" adapters. Feed the output signal to the female end of the first "Y", and plug the male ends into the other 2 "Y" adapters. Then, the 4 plugs you have left on the ends go into your amp inputs.
Hope this helps.
Apr 24, 2009 | Power Acoustik CLASS D SL-5500D Car Audio...
Fan on amp runs constantly. will this drain my battery?
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Aduz
Mar 22, 2009 | AudioBahn A2002T Car Audio Amplifier
Car Audio & Video Logo
119 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
