Question about Zanussi Washing Machines
Zanussi IZ16 trips switch when plugged in/turned on?
  • 566 Answers
As you do not mention make /age of machine and was this a sudden fault ? for now best to carry out the simple progress of elimination as to what is causing trip out to operate? start at the plug? check the wires in plug then wiring to machine motor for any damage to wires insulation? have you tried another appliance in the socket ? to see if ok? if trip operates then investigate socket ? any more info ? would help to advise on further options ?
Posted on Nov 01, 2008
My zanussi dehumidifier's tank full light comes on and the machine stops wehen the tank is practically empty. Is there any easy way to fix this problem myself
Most dehumidifiers have a switch near the top right of the tank or left. When the tank gets full it tips out a bit and trips the switch to turn it off and light the indicator. Make sure the tank is sitting properly as I have done this before, and had the same problem, or check and adjust the sensor(if possible) to fix the problem. The tank not sitting right can cause it to trip the switch with a mostly empty tank.
Nov 22, 2014 | Zanussi Washing Machines
Zanussi FLE1416W trips consumer unit fuse switch.
A shorted wire or component somewhere
Nov 04, 2017 | Washing Machines
Zanussi washing maching keeps tripping trip switch
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 14, 2011 | Zanussi ZWF1420W Front Load Washer
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
Our zanussi cooker is tripping out. Any idea what fault might be? Is it worth getting a zanussi electrician or a local electrician to look? Thanks in advance
if it trips as soon as you turn on a certain function that may point you in the right direction.If it trips when you just turn on at mains with no funtions set then it would be advisable to get the zanussi man out most leckys will find fault but tell you to get service man to sort it.
Hope I was helpful.
Good Luck.
Apr 25, 2010 | Zanussi ZBF360X Electric Single Oven
Zanussi tc 7102w and when i turn it on it trips power
element short to ground.. coins hair pins clean try again
Aug 17, 2009 | Zanussi TC7102W Electric Dryer
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
My dishwasher when switched on keeps throwing the trip switch
Try plugging into another socket preferably one that uses a different circuit. It could be a fault in the socket.
Feb 18, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
138 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
