Marantz pm40 problem with left channel, some sound coming through but much reduced volume - this is effecting both main & sub.
3 Suggested Answers
  • 81 Answers
SOURCE: UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Posted on Dec 15, 2006
marsrover
  • 682 Answers
SOURCE: Loss of volume on left channel
please repeat speaker setting from your manual and confirm that left channel is ok.-invert left channel plug with right channel plug if the problem moves from left to right you will have the problem in your speaker or its cable-if not the problem in your receiver itself.
you can apply contact cleaner in volume control and move it forward and backward and test.
Posted on Jul 06, 2008
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
I have a Marantz Digital Integrated Amplifier PM75 and experiencing with LP's and CD's that I get a loud popping sound , thereafter no sound until after several minutes when it comes back on.
If the sound is common to both channels plus on different functions, it is either a part that is common to both channels or is in the power supply. It will be either in the main pre-amp or power amp, or power supply. If you can turn the bad sound down, it's before the volume control and it's unlikely to be in the power amp section. If you can't turn the bad sound down, it will be in the power amp section.
Remember stereo amps are two mono amps joined together. So the two channels have separate parts for each channel. However some use IC's that have both channels running in them, they can be suspects in this case.
Jan 11, 2016 | Marantz Audio Players & Recorders
My marantz stereo amplifier PM420 is having a problem of uncontrolled volume and distorted sound output..when putting on higher volume its switch relay on on its main amp. section switch off. Pls help.tnx
The part of the amp you switch in (to get more power) has failed, its probably only on the left or right channel, not both. Its either a pro-repair (expensive) or replace or live-with-it
Dec 14, 2013 | Audio Players & Recorders
I have a Marantz PM6010SE K1 signature amp - just for listening to CDs, if anyone remembers them. The amp creates a low level (mains) buzz in the left speaker. If I turn up the volume to max the low...
Use on the control buttons and other switches balance contact spray as the first step let it work for a few minutes.
Control the print for some loose components (solderings) by carefully some manipulation and movement on print and components with a wooden or plastic object, because solderings on active heat-conducting components have allways high priority on the end stage, and in power supply primary you can become early loose components in the solderings if the manufacturer has used leadfree solder. If you have after this no improvement then ALLWAYS refer the damaged to find components replace always twice (on both sides) each other replace if a damaged deformed capacitor or diode was found both as well left as right the same brand components , be carefull in replacements its very important because of in most repairs refurbishing for tonal influences Passive components as example (only suggestion) to take a capacitor 10Volt 330 MF then replace it for a 16 volt 330 mf the size should in most case be the same of the component its very important for tonal effects and balance, in most repairs is that more size format on capacity sounds better as the new order components become smaller on the same voltage its better to get the higher voltage capacitors with the same size as the old lower voltage ones.
http://akdatabase.org/AKview/albums/userpics/.../Marantz%20PM6010F%20Service.pdf
Jun 27, 2017 | Marantz Audio Players & Recorders
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
Marantz pm 7200 lost sound, only works when volume is up high, still looks like there are no high or medium frequencies.
You have either lost the pre-amp stage or the Main Amp stage. Since you have a problem on both channels it most be a part that is common to both channels. Something like an IC I would suspect.
Oct 31, 2009 | Marantz PM7200 2-Channel Amplifier
Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Apr 24, 2009 | Marantz PM-15S1 2-Channel Amplifier
Pioneer deck kicker sub 2 mossfit amps
scanman84: i would recommend using the 2 channel 300W amp to drive the dual voice coil alone. i wouldn't combine the single channel amp with the 2 channel. you can't tie the 2 channel outputs together & use that on 1 voice & attach the single channel amp to the other, plus there could be slight differences in amplification & timing which, could cause the sub to have minimal movement or cause a canceling effect which would reduce the spl, sound pressure level. if you need more volume use the lowest impedence speaker recommended by the amp's mfg & if you need serious volume, go with a higher output single 2 channel amp. just make sure you have sufficient wire size to handle high powered amps. example, 8awg wire is rated for 73 amps. also make sure the amp is well grounded with nut & bolt connections to the frame & that there is good ventilation.
peace-out
Jan 06, 2009 | Car Audio & Video
Muffled/bad sound on 1 channel of Marantz PM4400 amplifier
Go directly to the main amp, follow the leads from the speaker terminals. And you should find something on an heatsink. If there are two transistors see if they are running hotter than the other channel. If you see any damage to them (compare with good channel) replace both!
If all you see is a black box with pins coming out of it you need to replace that. They sometimes have the letters STK on them.
Replace both types with the letters and numbers of the same type. IE 2SC 1220 or STK 589.
Dec 17, 2008 | Audio Players & Recorders
1974 marantz model 2325 reciever and want to hook up a powered subwoofer ?
Hi jdwoomer
BEST WAY
Your amp has PreOut and Main In RCA connectors on the rear, you could make up an adaptor cable (or buy one) to split the post vol control signal at this point, and then use line level from here to drive the sub.
OR
Most powered subs have a speaker "high level" input, where the sub "sniffs" off signal from your speaker output. When setup like this the speakers and amp connect to the back of the Sub.
Either way, you can do it... Marantz were making nice gear back then... a collectable these days :) Any questions, I am here to help.
regards
robotek
May 06, 2008 | Marantz PM7200 2-Channel Amplifier
218 people viewed this question
 Grubhead
Grubhead
