Problem with Turion Ml-40
I have Amd Turion ML-40, 2,2 4000+ procesor in my laptop, he blooking and work, block and work. Can I by a same procesor and how much. Can I fix this problem. I am from CROATIA. :-)
I change the thermal past,i clean all hardware from all dross. and nothing. He don't give me a error message. just freezing, and work. He is slow, he need a 5 - 10 minutes to stand up a windows. I can't buy a processor on e-bay, because I am from Croatia in the Europe.
Posted on Nov 02, 2008
    Scholar:
  • 59 Answers
You can buy the same processor and it costs around $165.  Check this link: http://www.dealtime.com/xPO-AMD-AMD-TURION-64-MOBILE-ML-40-2-2GHZ-35W-L1-128KB-L2-1MB
And for the second part of the question, i did not really understood whats the problem.Can you be more clear... Can u give me the error message,the OS you use and which program makes it to freeze?
Generally this freezing happens when the processor is getting overheated.You may have to change the thermal coolant paste applies to the processor.Check out with your nearest hardware expert.
  • K.Sri Harsha Varma
    K.Sri Harsha Varma Nov 03, 2008
    You should have commented.Instead you posted your post as a solution.Hence i was unable to know.
    For your information, Processors generally wont go wrong unless in rare cases.Some thing might be wrong with your Chipset or ram.May be any of the IC's are getting overheated in the chipset.
Does the amd turion 64 ML-32 support PAE, NX, and SSE2?
I doubt it will, the RAM alone will possibly be too small.
Sep 27, 2014 | Computers & Internet
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
I need to install Mulimedia Audio controller driver for AMD turion 64 ML-34 processor
Go to amd website, under support type in the model number. They have all the drivers for the motherboard there. Has nothing to do with the processor.
Dec 12, 2008 | AMD (90613) PC Desktop
Laptop
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Format
when you start up the laptop, there should be a recovery option, on the partitioned drive.
Jan 14, 2008 | Packard Bell Easy One Silver 2120 Notebook
Computers & Internet Logo
390 people viewed this question
David Payne
David Payne
