Question about Radio Shack Pro-97 Handheld Scanner
No freqency numbers showing when scanning
When scanning frequencies, instead of showing the frequency numbers, only the numbers 56.8. appear - when the scanner locks in on an active channel, the frequency numbers reappear. What is going on?
This is normal ....thats the banks its scanning freq. or tags only show when it stops try reading the manual or downloading one....
Posted on Nov 20, 2008
I am trying to figure out how to set the scanner frequencies
  1. Press hold then enter then enter the channel number where you want to store a frequency. Then press "FUNC" and "PGM" and the channel number will appear.
  2. Use the number keys to enter a frequency including the decimal point you want to store.
  3. Press "E" to store the frequency into the channel.
  4. Note - If you entered an invalid frequency in step two "ERROR" will appear and it will beep three times. Enter a valid frequency.
  5. The scanner automatically rounds the entered number to the nearest valid frequency. ie an entry of 155.174 will automatically be rounded to 155.175
  6. When you enter a frequency into a channel, the scanner automatically turns on the delay function and "DLY" appears. When delay is turned on the scanner automatically pauses scanning.
Mar 19, 2011 | Uniden BC72XLT Handheld Scanner
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
What are trunked freqencies
A trunked radio system is one where users share a number of frequencies that are rotated by a computer, and while your scanner may be able to tune in to specific frequencies within the system, it is not capable of following a user when the frequencies are changed. In other words, you may pick up a lot of activity on a frequency in the system, but you'll have a bunch of partial, cut-off conversations involving different users. For more information/discussion of trunked systems, I suggest that you visit www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 22, 2011 | Uniden BC60XLT-1 Handheld Scanner
Im trying to find freqencies to program in my scanner but dont no how to get the frequencie numbers for my local area but not haveing any luck. do i have to buy these or how do i get numbers? thank you
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Jun 06, 2010 | Uniden BC340CRS Base Scanner
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
Notes:
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
Eurovox - setanta channels
try this it should help you get channels back.
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
Using this method indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
Dec 10, 2008 | StarTech.com StarView SV211K 2-port KVM...
Loss of starview channels
No setanta on 5401
I had this problem so i scanned them a few times and they sorted them self's out . another alternative is finding any particular channels or are missing. i have tried this also.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? ,the ?? being 2 digits.
Using this method my indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
I also gained a few extra channels.
The other transponders may have been picked up by scanning other providers. if no luck let me know .
Dec 08, 2008 | Audio Players & Recorders
Got all the channels except setanta, can any1 help ?
Dec 08, 2008 | StarTech.com StarView SV211K 2-port KVM...
BC72XLT
Here is the directions to store frequencies in your scanner:
Storing Known Frequencies
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
accept.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
