Question about Frigidaire Washing Machines
Frigidaire Automatic Washer...Model FW905ES2 Serial # XC73458914
Gyrator only gyrates to left and right once, then gyrates to right a complete turn for the rest of the cycle....can you suggest what the problem might be?
Thanks..Bob
4 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: gyrator is stuck and will not move there is a
FAV6800A or FAV9800A correct?
You may have One-Way Roller Clutch rusted solid and the Motor drive belt is slipping burning rubber smell?
Please confrim the model number of your machine and we will go from there.
Posted on Dec 31, 2009
pctech1
  • 1940 Answers
SOURCE: The gyrator on my washer
Without the Make and Model number of your washing machine, I can't point you to the parts that will be needed to fix this problem. I recommend replacing this washing machine because fixing this problem can be troubling, and expensive. Also, if the gyrator has gone out, it's only a matter of time before the motor goes out, or the electronic controls, etc.
If you are mechanically inclined, and are familiar with working on washing machines, you may attempt to disassemble the gyrator assembly and check for socks, clothes, etc. that may have gotten inside the gyrator and possibly put it in a bind. Else, you will need a service technician to fix this problem.
Posted on Jun 07, 2011
jumptrout51
  • 3361 Answers
SOURCE: how do you remove the
Pull the top piece off. Remove the bolt underneath the top cover.
Pull up on the agitator to get it off.
Posted on Sep 07, 2011
Remove frigidaire agitator
I appreciate your inquiry, friend!
Based off the information you have provided you need to remove the agitator inside of your Frigidaire washer. Could you please provide me with your model number? I may be able to find additional information once I have that number. You should be able to locate the serial tag on the door frame of the washer. Once I have that information I would be happy to assist you. -Matt
Feb 22, 2015 | Frigidaire Washing Machines
My front load washer frigidare door is rusty acsess door is rusted off its only 6 years old
Thank you for your post, debra!
I understand that the front of your Frigidaire washer is rusted. Typically rust is not covered under the warranty and in most cases, the door will more than likely need replacing. Could you please provide me with your model number? You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Once I have that information I can provide additional information for your washer. -Matt
Aug 13, 2014 | Frigidaire Washing Machines
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
How to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
How do you remove the gyrator from a frigidaire gallery top load washer
Sep 07, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Gyrator is stuck and will not move there is a
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
Mar 19, 2009 | Maytag Washing Machines
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
