Question about Sharp AR-M355N Copier
Error Code E7-03
There is an error code E7-03 on our Copier - I was wondering if you can tell me how to fix this.
thanks,
Noel
  • Anonymous Dec 10, 2008
  • reyfactor Dec 10, 2008
    Sharp AR-200 with error code E7-03,please help me to fix this problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
THAT IS LASER PROBLEM.JUST CHECK LASER UNIT .IT IS SENSETIVE UNIT.CALL A ENGINEER TO SOLVE THIS .ITS BETTER.BY MIAN AKHLAQ
Posted on Dec 18, 2008
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Error U2 on a Sharp AR-5132
There are 3 different U2 codes, but all are kinda related. They are all communication related errors to the MCU board. Firstly make sure the developer unit is in securely. You try canceling the error code by going into SIM mode. press the following keys one after the other "#" "interupt" "C" "interupt". enter 14 and press start, this should reset the copier. make sure the copier is restarted.
If reset does not work and developer unit is in securely then it would more than likely require a technician.
Hope this helps.
Apr 05, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code 630
Kindly let me know the Brand and Modle of your copier
Jan 02, 2009 | Office Equipment & Supplies
Error code E000003-0000
im not sure what you had changed but this code is for the upper heat roller thermister detecting an heater error if it wont reset it is bad
Dec 18, 2008 | Canon imageRUNNER 5000 Copier
Error Code E000 on Cannon Imagerunner 1600 Copier
Get into service mode by pressing.....
additional functions key (*) key and then...
ID(#) key...
Scroll down to PRINTER then press OK
Scroll down to PRINTER RESET
then indicate YES(*)
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Any problems please get back to me
Thank You
Mar 21, 2008 | Office Equipment & Supplies
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Dec 20, 2007 | Canon imageRUNNER 5020 Copier
Sharp AR-M355N Copier Logo
651 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
