Question about Samsung Televison & Video
I have a old Samsung DVD-V8600 and it will not play discs anymore. All it says is "Loading". I have tried several discs with same results. I have played the same discs on another DVD player and it works. How do I get the discs to play.
  • 2 more comments
  • gm3warden Nov 01, 2008
    I got 3 replies but all from the same person. Would like to see if there may be something else to try.
    i tried manually cleaning - no help. Will try disc cleaner. Thanks
  • gm3warden Nov 04, 2008
    I opened and cleaned eye manually. I bought a cleaner. Still problem exists. Disc goes to "loading" and will not move. However, cleaner disk in audio not picture seemed to work fine and went through the 5 items.
    Thanks. I hate to go to a professional repair person because of the price of the original DVD. Maybe I just need to get a new one.
  • 10,594 Answers
Optical lens gone. Needs replacement and cost would be higher then player's worth.
Best option is to buy new dvd player.
Good luck.
Posted on Nov 04, 2008
    Genius:
  • 1,550 Answers
Purchase A DVD laser head cleaning kit assuming the laser head is just dirty.
The best method of cleaning the laser head is as Follows.
  • After removing the appliances Main Power plug.
  • And taking off the Top or outer Casing, allowing access to the players Laser-Eye.
  • Apply a small amount of alcohol or petroleum fluid, to a cotton swab ( Bud ) gently wipe the moistened ( Not Soaked ) bud across the glass laser eye, several times.
  • Re-assemble the casing, and try a dvd.
If this does not work .You can assume the laser or laser power Diode has burnt out.
And time for a new Player.
Posted on Nov 01, 2008
  • Samsung Master
  • 1,879 Answers
Optical drives uses LASER in tandem with a LENS to read the data off the CD/DVD.
LENS get dirty, a CD Lens cleaner is suggested for this.
LASER on the other hand dies.
  • 94 Answers
Gm3warden hello,
Are you trying to play original DVDs, or burned DVDs?
If the second answer is the correct one, try an original DVD.
Also try playing a regular CD, for example a music album.
If none of them work, it seems as though there is a lens problem.
I would suggest going to your nearest computers/video rentals store and getting a CD lens cleaner disc.
Try using it twice or maybe even three times. Then try playing the DVDs again.
If it does not work, it seems as though the reading lens is out of place or burned - this might happen from time to time, especially as you mentioned your player to be relatively old. If that is the case, it might need a professional physical repair.
    Master:
  • 505 Answers
Open the tray. Clean the lens by soft cloth by hand maually, lens cleaning will solve the problem.
Thanks
    Genius:
  • 2,035 Answers
Try to cleans the lens with lens cleaner disc ,after cleaning the lens and then try to play the disc ...
Please let me know the results ......
Goof luck....
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
  • Priya darshan Nov 01, 2008
    IF you still face the problemt hen you will have to get it repaired.
No disc spin-up when inserted or when powering up
The problem is in the pladder motor that spins the DVD, the motor needs to be replaced, but the problem is they only sell the laser pickup assembly, which is very expensive.
Mar 13, 2012 | Samsung DVD-V8600 DVD Player/VCR
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
When I put a dvd in it says "loading" for a good
Try cleaning the laser lens. Either opening the unit and cleaning with a cotton bud, or try a lens cleaning disk.
Oct 24, 2011 | Televison & Video
Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
Mar 13, 2010 | Samsung DVD-V8600 DVD Player/VCR
When a disc is loaded, it reads no disc, and disc cannot be played.
It is very possible that the lens motor has burnt out. Sometimes the capacitors on the motherborard short out causing the gear timing to go out..
The only thing you can do to fix this is to take the cover off. Get cotton swab and dip it rubbing alcohol and clean the glass laser eye with it.
Jun 03, 2009 | Samsung DVD-HD850 DVD Player
When I load a DVD into the Samsung player, it says it's loading, about a minute later it states, "...can't display disc, check disc.
hi emiller,you might be playing a format not known or cannot be played on ur dvd player check if any original format (dvd) works on your player.
May 11, 2008 | Televison & Video
Problem reading DVD-R
Need more info.  Do other DVD's play on the Samsung?  Some players play DVD-R and some don't.
Mar 25, 2008 | Samsung DVD-V8600 DVD Player/VCR
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
